Finless Bob released a new 1.3 version of his custom rom for the Minix Neo X5.
For those who want to flash it with CWM, I used the images from his rom kit to make some CWM flashable zips.
For rom 1.2b I did 4 packages with different combinations of 1080p/720p and with or without airpin.
This time, Bob added a set of overclocked kernels, which makes the number of different combinations too high to have a complete kit for each one.
So I made only one full ROM zip (with 720p and airpin disabled), but I also made multiple kernel flashable zips.
Here is the archive containing all these flashable zips :
neo_x5_finless_13_cwm.zip
So for example if you want 1080p with airpin enabled, OC GPU at 533Mhz, and DDR at 533Mhz you can flash the rom first : neo_x5_finless_13_720_noair.zip
Then flash the kernel : kernels/neo_x5_finless_13_kernel_1080_air_oc_gpu533_ddr533 .zip
If you want to use another kernel later, you can simply flash the kernel package without flashing the full rom first.
Warning : this ROM is for Minix Neo X5 only. It won't work on other models. So DO NOT flash it on Neo X5 mini.
Also note that, due to the number of packages, I didn't test them all. So if you have problems with one of the zips, please report on this thread.
Enjoy
Thank you Finless for this great ROM, and thanks Leolas for the CWM zip package I used as a base.
The complete procedure :
What will you do with it?
- Download the package
- Extract it on your SD card
- If you have CWM installed, simply reboot to recovery, either with my "Reboot App" or with the specific way of your device to boot to recovery
- If you don't have CWM installed, find a way to install it first, then go to the previous step
- Once into CWM recovery, make a backup first (backup and restore > backup to external sdcard)
- Wipe data if you want to flash the whole rom package and have another version.
- Then choose "install zip from sdcard"
- Then "install zip from external sdcard"
- Then select the rom you want to flash
- Then "Reboot system now"
For reference, here are the zips of the previous version (1.2b):
Finless ROM 1.2b 720p & airpin disabled
Finless ROM 1.2b 720p & airpin enabled
Finless ROM 1.2b 1080p & airpin disabled
Finless ROM 1.2b 1080p & airpin enabled
As asked by some users, here is a CWM flashable zip of the new MINIX rom :
NEO_X5_20140306_CWM.zip
It is just the stock rom (not even rooted) I extracted and re-packaged.
I tested it, and it was flashed with no problem, over my previous install of Finless 1.3 rom + CWM.
