CWM Minix Neo X5 Roms
Originally posted by petrus View PostTo unpack the img, I used : http://www.freaktab.com/showthread.p...eaktab+kitchen
You'll need linux, and some other tools referenced in the first post of the kitchen thread.
About the 1080p version, I saw it on minix forum. But I don't know who did it, so I don't know if it is ok to re-package it and put it somewhere else.
It was posted by minix on minix foruns, so I think it's official
I want to cook my own rom preinstalling all common apps I always install and removing unnecessary onesPlasma: Panasonic TX-55ST60E
HTPC: LC-Power 1320mi :: Sapphire PURE WHITE Fusion E350 :: 4GB DDR3 :: SSD Corsair Nova 2 [SO] :: 4TB [Storage] || Android PC: Minix X5
powered by Win7 :: XBMC Gotham :: SABnzbd :: CouchPotato :: SickBeard
Minix Neo X5
hi petrus i downloaded and flashed via cwm your NEO_X5_20140306_CWM.zip firmware,but my neo x5 dont boot,only black screen
i flashed several times,and i see that kernel is not found and dont install during flashing.
ok i extracted everything from this zip,kernel exist but not flashed,i erase kernel and i put a kernel from finless 1.3 1080p cwm,only kernel without boot img,then i ziped all,and flash via CWM.and i confirm it works great,real full HD,tested wifi and full HD movies,everything is ok,thanks for your work
sorry for my bad english,Iam from Russian Federation.i hope your will understand me,
Finless Bob released a new 1.3 version of his custom rom for the Minix Neo X5.
For those who want to flash it with CWM, I used the images from his rom kit to make some CWM flashable zips.
For rom 1.2b I did 4 packages with different combinations of 1080p/720p and with or without airpin.
This time, Bob added a set of overclocked kernels, which makes the number of different combinations too high to have a complete kit for each one.
So I made only one full ROM zip (with 720p and airpin disabled), but I also made multiple kernel flashable zips.
Here is the archive containing all these flashable zips :
neo_x5_finless_13_cwm.zip
So for example if you want 1080p with airpin enabled, OC GPU at 533Mhz, and DDR at 533Mhz you can flash the rom first : neo_x5_finless_13_720_noair.zip
Then flash the kernel : kernels/neo_x5_finless_13_kernel_1080_air_oc_gpu533_ddr533 .zip
If you want to use another kernel later, you can simply flash the kernel package without flashing the full rom first.
Warning : this ROM is for Minix Neo X5 only. It won't work on other models. So DO NOT flash it on Neo X5 mini.
Also note that, due to the number of packages, I didn't test them all. So if you have problems with one of the zips, please report on this thread.
Enjoy
Thank you Finless for this great ROM, and thanks Leolas for the CWM zip package I used as a base.
The complete procedure :
What will you do with it?
- Download the package
- Extract it on your SD card
- If you have CWM installed, simply reboot to recovery, either with my "Reboot App" or with the specific way of your device to boot to recovery
- If you don't have CWM installed, find a way to install it first, then go to the previous step
- Once into CWM recovery, make a backup first (backup and restore > backup to external sdcard)
- Wipe data if you want to flash the whole rom package and have another version.
- Then choose "install zip from sdcard"
- Then "install zip from external sdcard"
- Then select the rom you want to flash
- Then "Reboot system now"
For reference, here are the zips of the previous version (1.2b):
Finless ROM 1.2b 720p & airpin disabled
Finless ROM 1.2b 720p & airpin enabled
Finless ROM 1.2b 1080p & airpin disabled
Finless ROM 1.2b 1080p & airpin enabled
As asked by some users, here is a CWM flashable zip of the new MINIX rom :
It is just the stock rom (not even rooted) I extracted and re-packaged.
I tested it, and it was flashed with no problem, over my previous install of Finless 1.3 rom + CWM.[/QUOTE]
Re : CWM Minix Neo X5 Roms
Originally posted by WillJamesasDasdasDasdasdAs
It's weird. I had no problem flashing it on my x5.
Maybe a CWM version problem ?
I don't know.
Hopefully Bob will make a new 1.4 rom based on this firmware. Then i'll make a zip from his images.
Thanks for the detailed report
I don't know.
Hopefully Bob will make a new 1.4 rom based on this firmware. Then i'll make a zip from his images.[/QUOTE]
ok,its a good news,will wait from bob 1.4 rom,my cwm seemed to be good.other fw flashed without problems, if you can add a kernel from the last firmware,i want to try it
kernel finless 1.3 1080p is well,but everything in the screen is very small,icons latters and other, i try another kernel 720p and this is well,big icons,huge latters, but i feel its a littlee slower
THANKS
Re: CWM Minix Neo X5 Roms
Originally posted by alkalinia View Postok,its a good news,will wait from bob 1.4 rom,my cwm seemed to be good.other fw flashed without problems, if you can add a kernel from the last firmware,i want to try it
I have flash cwm for my minix neo Mini 5 but i cant control the Menu.
Not with the mouse ore Keyboard and I cant flash from PC Because no reaction from USB Port.
Can i find a automatic zip to flash from sd card like mygica?
The PC solution is very stupid and I am on bootloop too. Cant do Nothing.
Originally posted by kram1974 View PostI am having the same problem after installing the latest firmware via CWM. Just reboots into CWM. I will re-download the zip and try again. Also, do you know where I can find the superSU CWM zip for rooting? Thanks!
Thank you
Enjoy
i need completly change a boot image and animation when device start on
or maybe its a way to change or erase all boot???
There are currently 1767 users online. 3 members and 1764 guests.
