CWM Minix Neo X5 Roms
    Remote Problem
    Hi all,
    I just flashed "1080p & airpin disabled" and now my X5 remote no longer works at all on the Minix and the only way I can use the Minix is by using a USB Mouse with Keyboard, any ideas how I can get the remote working again? Also confirm the remote is working and was working before flashing, thanks.
      When you say X5 remote are you talking about the app to run on a different device? If so, I believe there are 2 versions of it and I think only the earlier one runs on Finless. My experience is, however, that that remote control app is far from the best one. I gave it up for DroidMote (the server is not free but it is well worth it IMHO).
      Originally posted by sojourner353 View Post
      Hi all,
        Hello, thanks for the reply, no it's not an app remote it's the IR one the Minix came with, been searching all day online and it seems I am the only person who has had this issue.
        I have gone back to BorgDroid's ROM and it's working again, the reason I want this ROM is it's 1080p.
          Is this also for the MINIX Neo X5Mini?
          If yes, will thit fix te freezes? It's makes me crazy. I never had it work good.
            Re : CWM Minix Roms
            No, sorry, only for Neo X5, not mini.
              Sorry, i'm new here, i've tried to search for freezing topics but i can't find it.
              I have the Minix Neo X5 Mini.. and want this problem solved.
              Do you know where i can find more tips or fixes?
                Re : CWM Minix Roms
                I don't have a x5 mini, so i don't know much about it. Try to look at all the threads in the minix neo x5, g4 section. There are a few threads about the x5 mini. At least one of them seems to give links to official minix neo x5 mini firmwares.
                  Please, update CWM files to NEW - Minix X5 - Finless 1.3 custom ROM
                    Re : CWM Minix Roms
                    Yes, I plan to make an update with 1.3 soon.
                        +1 please.
                        Thanks in advance
                          I updated the first post with new Finless 1.3 version.
                          Petrus.
                            Many thanks for your work! Greetings from Russia
                              Many thanks from Seattle, WA USA as well. I am getting ready to install now. And thanks for keeping links to the 1.2b versions.
                                Big thank you for providing a CWM version of Bob's lovely 1.3 ROM, my X5 is loving it.
                                Only 1 small issue, am struggling to get running in 1080, have flashed several different non airpin 1080 kernels, but to no avail, when I go to the screen settings I only have 720 & lower resolutions available.
                                Am I missing something?
                                Cheers
                                Rich
