CWM Minix Neo X5 Roms
    Re : CWM Minix Neo X5 Roms
    Originally posted by Jumper View Post
    and i have asked for a newer version of CWM!!! Did you realy think the finless tread is the right place for this question!
    That’s realy confusing for me!!!
    In fact, as you asked Finless, i thought it would better to ask him on his thread, where he released the original 1.3 rom. On this CWM rom thread I only took his rom parts and repackaged it. But i didn't even include CWM inside the package. There are only system.img, boot.img and kernel.img. no recovery.img.
      @petrus
      ahhh.. ok, i understand! Sorry, it was my fault! Shame on me!
      Do you think my english ist bad??? Did you forget, i am from germany! Sorry!
        @petrus
        No problem, I understand how it can be confusing.
        Not to mention that the 1.2b CWM packages I made include in fact a version of CWM too (which can cause problems as it overwrites the version of CWM you may have before.
        So I did not make the same mistake in the 1.3 CWM package. If you flash it, you will keep the CWM version you had before.
          cwm Recovery
          I can not install
          I took NEOX5_CWM
          Rename update
          I clicked yes to install
          Showed me that
          Why?
            Re: CWM Minix Neo X5 Roms
            Originally posted by haim85 View Post
            cwm Recovery
            I can not install
            I took NEOX5_CWM
            Rename update
            Showed me that
            Why?
            The system just tells you that after installing this update.img, if you choose to not automatically remove it, it will be detected again on next boot and you will always be asked to install it. So you can answer yes here. The update.img will be flashed, then removed from the device.
              @petrus
              I think, this isn’t the problem! The problem is, that flashing the CWM-Recovery has failed and user haim85 dont’t know why! Please can you explain him the right way to do?
                @petrus
                I don't remember right now where i downloaded CWM for X5, but from what I remember, it seems that the way he does flash it is correct.
                  I know (thanks XDA*) user haim85 has trying to use this way:
                  1.) Use a file explorer and move the CWM recovery zip that you just downloaded to the root of your /sdcard directory and rename it "update.zip"
                  2.)You should now automatically be prompted to install the update using the system's stock updater process -- Accept the update.
                  If i remember correctly, i did not use this way! I think to remember me, that i have rebooted into original recovery and flashed the NeoX5_CWM.zip using the install function directly there. Is that possible?
                  I hope, you will understand my horrible english!
                  Edit:
                  * I have seen that user "haim85" has posted the same problem on XDA yesterday!
                    Hahaha I know it's asking deletes
                    Menu recovery did not appear
                    I rename update.zip
                    It did not work
                    Change update without zip
                    It is normal to me, I chose Yes
                    Did not show the total recovery
                    I like the picture appeared always
                    Do not understand how to do this it will work on the original ROM version for mx5
                    I installed Rom neo_x5_finless_13
                    After this
                    I installed cwm it worked
                    The question is how to do it without installing this Rom
                    Hope you understand my bad English
                      I rename update.zip
                      It did not work
                      After this
                      I'm not sure man because I just did the update.zip method on official 005 and it worked fine for me. I have even had it ask to flash it from a usb flash. I bet you it can be flashed also with good ol adb if there is a .img instead of just a .zip.
                      Sent from my NEO-X5-116A using CrappaLinks
                        I rename update.zip
                        It did not work
                        After this
                        Maybe this link is useful for you:
                          i installed this rom yesterday,it seems to work very good except flash player.
                          I tried several flash apks but i wasn't able to make it work.
                          What can i do?
                          Thanks.
                            I just did it the same way I do for all my devices. Just install it straight from adobe (search "archived flash player versions.) The latest version 11.1.115.81 works just fine for me on all of my devices as far as I can tell without more specifics of your issue.
                              CWM version of latest 4.2.2 stock ROM
                              Can we get a CWM version of the latest MiniX release of 4.2.2? I hear it is finally stable and would like to try it even if it is not rooted or customized.
                                I'm not really a rom dev, but i'll try to take it apart and make a cwm flashable zip from it.
