So, maybe your display doesn't allow 1080p, or you are looking to the wrong menu. I think it is in screen/hdmi menu.
CWM Minix Neo X5 Roms
Re : CWM Minix Neo X5 Roms
Display supports full HD (was running 1.2b in 1080p before).
Was looking in the screen/hdmi menu.
Guess I'll have to do some more prodding about.
Cheers for the swift response though
Rich
Re: CWM Minix Neo X5 Roms
the kernels must be compatible with minix official 005 right? thanks for all that you do Petrus!
edit- the 1080 oc 533/533 seems to flash fine for me over the stock 005, but as others have found antutu scores don't improve
here are some of my scores on my setup
oc 533/533 averages 12463
stock gives me an average of 12370 on 3 tests
i hadn't noted the specific gpu/ddr performance yetLast edited by linux.masterkey; 29 January 2014, 22:35.
Antutu scores don't say nothing about device performance...
It's better to test the device yourself and reach some kind of conclusionPlasma: Panasonic TX-55ST60E
HTPC: LC-Power 1320mi :: Sapphire PURE WHITE Fusion E350 :: 4GB DDR3 :: SSD Corsair Nova 2 [SO] :: 4TB [Storage] || Android PC: Minix X5
powered by Win7 :: XBMC Gotham :: SABnzbd :: CouchPotato :: SickBeard
Originally posted by redglory View PostAntutu scores don't say nothing about device performance...
Originally posted by Kemden View Posti tried the kernel of the 720 noair and the 1080 air oc stock
now i tested a lot of kernels from your .zip almost the same
flashed 1.2b all ok -.-
What are you doing there???!I have tested all kernel from the Finless 1.3 package and all cwm-rom too. No problems at all!!
Did you deleted cache /dalvic / data and system before flashing a new Firmware?
The simple way is to use the "wipe data/factory reset" option in cwm recovery menu.
But i’m sure you will know that!Last edited by Jumper; 06 February 2014, 21:47.Do you think my english ist bad??? Did you forget, i am from germany!Sorry!
Originally posted by Jumper View PostDear @Finless
is it possible to rebuild the 1.3 package with a newer version of CWM? I prefer version 6.0.4.3 becaus this is the version from my smartphone also.
Sincerely yours
JumperThis thread is only for the re-packaging of finless rom as a cwm flashable zip.
Originally posted by petrus View PostMaybe you should ask it in the original thread of Finless romThis thread is only for the re-packaging of finless rom as a cwm flashable zip.
and i have asked for a newer version of CWM!!! Did you realy think the finless tread is the right place for this question!
That’s realy confusing for me!!!Do you think my english ist bad??? Did you forget, i am from germany!Sorry!
There are currently 1837 users online. 0 members and 1837 guests.
