TECLAST T98 32GB new scatter file (user space and system enlargment)
    These are new scatter file for 4GB 6GB 8GB 16GB userdata partition
    1. Make TWRP FULL backup (not on the tablet) mandatory remember intsd partition will be format backup it also! YOU ARE BEEN FORMATTING YOUR TABLET
    2. Use SPFT to upload Stock original ROM with Stock original RECOVERY!
    3. Copy whatever NEW scatter file in the folder of Stock ROM
    4. Use SPFT with NEW scatter file and upload FULL Stock original ROM with Stock original RECOVERY in FIRMWARE UPGRADE mode be sure NOT to uncheck anything
    5. START it in recovery mode
    6. Make a Wipe Factory RESET to finish resizing partition
    7. Restart in normal mode once
    8. Use SPFT with NEW scatter file in DOWNLOAD mode and upload TWRP recovery ONLY
    9. Restore the backup with TWRP
    10 Restart .... Enjoy!
    YOU can't loose your IMEI if you make a full TWRP backup (NVRAM partition)
Name:	TECLAST T98 4GB.png
ID:	499072 Click image for larger version
Name:	TECLAST T98 16GB.png
ID:	499073 Click image for larger version
Name:	TECLAST T98 8GB.png
    Enjoy
    thanx to devilzwolit for collaboration
    I think it's interesting I'll try it.
    My serial is 123456789....... It's strange . Do you have the same serial ?
      ...ABCDEF
        Exact plus horrible sound on headset
          I have TECLAST T98. Tab works fine, but i have one query, whenever i install any app from the play store, it gets installed in a Internal Memory which is only of 2GB & not in the Internal Storage of 32GB. I have also inserted a memory card of 16GB & have set my default installation path to SD Card, but still no change.
          As a result, now that internal memory of 2GB is getting full & i can not update or install any more apps from the play store. Please help me.
            If you have root and twrp recovery you can use my scatter file
              Where is the Twrp you used ? And do I need root for flashing your scatter file ?
                twrp is here https://mega.co.nz/#!gRAhRYCb!QPhuss...RRXGKH574BC_WE
                this is a modded version of hanuma50 from 4pda.ru http://4pda.ru/forum/index.php?showt...ost&p=38656360
                i add only missing font so honour is to him
                you dont need root
                if you want you can try 8GB userapp
                ciao
                PS its mandatory you use firmware upgrade mode in sp flashtool! No root
                Sp flash tool 5.1516.00 http://www.mediafire.com/?qp5a1xo34z8uzd6
                  Hello hocuspocus69:
                  Can you please guide us in Step by Step way, to increase the storage space on T98 ?
                  Also, if you could guide us in installing TWRP & ROOTING T98, please.
                    Originally posted by hocuspocus69 View Post
                    I've done a new s
                    file with 2GB SYSTEM partition and 4GB USERAPP partition
                    to use it you need to follow this path
                    make TWRP FULL backup (not on the tablet) mandatory
                    use SP FLASH with scatter file attachment but in firmware upgrade mode with stock or rileyrom firmware
                    (you need to format tablet to change partition size this is why you need backup I haven't loose my IMEI because we don't format NVRAM partition)
                    after firmware upgrading finished
                    simply restore your FULL TWRP backup
                    now you will have
                    1.91GB SYSTEM partition
                    3.91GB USERAPP partition
                    20.99GB INTSD partition
                    before you had
                    1.24GB SYSTEM partition
                    1.94GB USERAPP partition
                    25.56GB INTSD partition
                    I think its the same for cube t7 t9 also!
                    It seems difficult that these can adapt to scatter cube T7 (Rom = 16Gb) and Cube T9 (Samsung EMMC).
                    I have long been trying to figure out how to change the partition date.
                    Uploading your files on SPFT is evident that modify the partition sizes of userdata and cache, but not the system partition that you say you have brought from 1,24 to 1,91Gb.
                    Why?
                    You could, using terminal with the command (cat / proc / EMMC) post the results after this change and if possible before the changes?
                    Would it help me understand how to modify the partitions of CubeT9
                      I think is the same for t7 and t9 (but i cannot try it) because scatter file are the same for teclast T98 16GB or 32GB model and CUBE T7 T9 also (some little difference only for different size of userdata partition) so what is important that if you modify scatter only to stay below 4GB on physical_start_addr of intsd partition if you have a model with 16GB EMMC
                      uploading my scatter in FIRMWARE UPGRADE mode create SYSTEM PARTITION of 1.91GB then if you put back your backuped system partition with twrp, because twrp backup only the contents not the size of partition, you have system partition size modified
                      so trick is from system partition on take linear_start_addr= physical_start_addr then modify partition_size as you want then the NEW linear_start_addr= physical_start_addr of next partition is the first start_address+partition_size and so on look that partition size intsd is partition_size: 0x0 i think this mean to the end of your emmc
                      sorry for my english
                      Last edited by hocuspocus69; 06 May 2015, 18:11. Reason: seem problem bigger than 4GB
                        I hope this is better than english everything is in Hexdecimal!Click image for larger version
                          The image posted corresponds to the original scatter and this part is perfectly equal to that of T9
                          You have a PM!
                            After some different try my method don' t work with 8gb partition size i will try with 6gb and 5gb later
                              OK I flash tablet with your scatter file it was not easy but not very difficult though.
                              What was mandatory is the driver from teclast.
                              Next is to flash recovery TWRP, then backup , then flash original firmware with the modified scatter file and TWRP recovery, then restore the backup.
