TECLAST T98 32GB new scatter file (user space and system enlargment)
    Yep
      And of course ... Good job. Thanks !
        UPDATED look http://freaktab.com/forum/mtk-based-...ent#post496235
          Does it need a new a redo for my previous use of your scatter file ?
          Rhône ?
            Rhône ?
            Which one do you use? There is a problem with real system partition sometimes after flashing with 2gb version doesn't enlarge really if you have seen it's good and intsd partition need to be format too but if you don't have this problem no problema! Problem are only just after flashing if you use it for a day and no trouble no problema!
              I'm talking about the 4GB first version.
                Probably you loose some MB if you can its better to reflash with no system modification or wait to monday I ve time to do some more test i change some byte in each scatter file
                  @hocuspocus69
                  I want to expand the apps memory from 2GB to 4GB. When I click on the attachments you posted, there is nothing under _4GB ( in fact, only the scatter file for _2GB_8GB is found, there is nothing for all the other options).
                    Originally posted by slim_thumb View Post
                    @hocuspocus69
                    Tomorrow i check it
                      reuploaded scatter and better description of method
                        Originally posted by hocuspocus69 View Post
                        If you have root and twrp recovery you can use my scatter file
                        Hello hocuspocus69,
                        Please let us know the steps in bit more detail please.
                          Originally posted by harshalhirve View Post
                          Hello http://freaktab.com/member/68105-hocuspocus69"]hocuspocus69,
                          Please let us know the steps in bit more detail please.[/URL]
                          Look at the first post and ask me about each point you don't understand
                          Sorry i'm not a native english speaking people!
                            So hocuspocus69 (or other knowledgeable members!), I'm a newbie to the MediaTek world, and just received a Teclast T98 32GB for a family member. Because the tablet is new, it has nothing to backup and neither do I care about installing TWRP recovery because this tablet is not for me. But before I begin setting up the tablet, I do want to increase the user data partition to 8GB because 2GB is quite small. Anyway, I've just downloaded the stock v1.03 firmware from Teclast, and unpacked it. Supposing I just replace the "MT6752_Android_scatter.txt" file there with your "MT6752_Android_scatter_8GB.txt", and flash directly, will this simply enlarge the user data to 8GB after flashing? I am guessing so, but since I am completely new to the MediaTek world, I'm just exercising due caution! Or would I still have to include your step 6, i.e. "Make a Wipe Factory RESET to finish resizing partition" to finalize things? Thanks in advance for the guidance!
                              If you want a brand new tablet without any personalization you can substitute scatter and use firmware update mode remember to wipe factory from recovery after flashing! Im not english native speaker so be carefully when you ask me something...lucky you
                                Thank you, hocuspocus69, especially for pointing out the need to use "Firmware Upgrade" mode. My SP Flash Tools was set to "Download Only" mode, and the distinction between these two modes is not clear.
