Nvidia Shield Concole.
Originally posted by Batfink32 View PostNice review :-)
Incidentally, does anyone know what's happening with the Grid games system? Is it becoming a paid subscription as it's free just now. It works amazingly well on this box through my 50mb net connection, it's stunningly good.
i'd like to know this as well. but i'm afraid the free will go away if i ask.. lol
I've downloaded it all and downloaded the cores. When I go to run the . Pce it doesn't work and if I auto detect the core, it says no support cores detected. Never used RetroArch before so maybe I'm doing something wrong?
Originally posted by bigall123Im afraid its going by the end of june. It will become a 2 tear games grid, 1 for lower end games & the other for the top end games. Its going to be subscription baste after june. You will pay a higher fee for the aaa, Grid. Lower for the lower end games.
Originally posted by saulin
Sorry the nightly builds seem to have many issues, if you don't mind can you try the stable release instead?
http://buildbot.libretro.com/stable/...i-v7a/1.0.0.2/
I downloaded the stable build and New adventure island. I then went into shader options and applied shadr. It runs fine as far as I can tell although Ive never used RetroArch before so might be doing something wrong. All plays fine and smooth though when I had a go.
And Retroarch had no issues recognizing the Nvidia Shiel Controller either?
Excellent. So it plays smooth even with the sabr shader? New Adventure Island is a good game to test because you can check the background as the character is running and see if you notice stutter or sometimes micro freezes.
Yeah, seems to be fine seems to play OK. The Shield is so powerful I'd be surprised if it didn't play to be honest. Here's a video I've recorded and uploaded of it. I think what I've done is correct.....
With the shader it looks 10x better
These should be your video settings. For refresh rate you can try to match the OS reported refresh rate. Or tey setting it to 60 or 60.05. If The shield can handle these settings. It's indeed very fast. Try to choose the sabr shader from this video menu. Try v1.1 and v3.0
imageupload
windows 7 print screen
screenshot windowsLast edited by saulin; 05 June 2015, 01:08.
There are currently 4069 users online. 1 members and 4068 guests.
