[modified rom]MK80_SDK3.0_150627 Tronsmart Draco remote fixed
    download: https://mega.co.nz/#!KtpHWRYa!cPY0H3...bCKuQ8Lo6Wk9d0
    heres something important i wasn't aware of.
    to enable 1920x1080 resolution change this in build.prop:
    remove or set to 10: ro.hwc.sysrsl=5
    set: persist.sys.disp_density=240
    reboot.
    now kodi and antutu show 1920x1080.
    this also fixes youtube full hd!
    note: users report Hardware keyboard issues with the latest rikomagic firmware. this bug is present in the original firmware and is not related to the mod.
    -added twrp 2.8.6.0 by abdul_pt
    -added nexus 10 spoof to build.prop for youtube in 1080p (you have to switch manually) and all apps available in playstore.
    -fixed softmouse in build.prop
    -changed the whole rikomagic /system/user/keylayout folder against the one from tronsmart (i really don´t want/dont have the time to find out which of theese files need to be changed so i did this.)
    beside that, nothing changed.
    twrp will only work when installed to emmc. if you install to sdcard you can use twrp and you can even flash zips to sdcard but you have to install it manually from the terminal (see twrp thread on how to do it).
    Look forward to the Upload,
    Draco has been on bit of a holiday for awhile time for a work out.
    Cheers
      Cheers
      upload finished
        Thanks Boxx
        In and Running on Draco
        Remote all seems to be in order and working well.
        Twrp all in order.
        Looking good
        I see the Netflix controls fights with lower task bar no bigy
        1750 kbps in Netflix, Normal
        Everything else looking pretty good
        More to come
        Cheers
        Just a Side Note:
        Don't know if others see this.
        I enable hardware keyboard, I get error on screen Google play services has stopped working. continually pops up on screen
        This also happened in the RKM only version as well.
        Power off and Hardware keyboard off again, Enabled get Google error, Disable google error stops weird.
          Yes, there is something wrong with the Hardware keyboard support.
          JD
            JD
            Can you confirm that the problem also exists in the unmodified mk80 firmware?
            Does the draco remote work correctly?
              Thanks JD.
              Boxx did see it happen in the RKM only version.
              Remote is 100% on Draco.
              Cheers
                Does the Tronsmart remote work correctly, including the power button? for those that have tested this firnware
                  I have not checked your ROM so far, but google service forced closings happened on my draco with both firmware based on sdk 3.0. So it nothing to do with your ROM.
                  JD
                    God firmware !!!!!!!But as I put youtube in 1080 thanks. Sorry by my englis
                      What do you mean?
                        Buen firmware ,pero como pongo youtude en 1080p. Solo puedo en 720 gracias............Just YouTube I can play Max 720 p
                        What do you mean?added nexus 10 spoof to build.prop for youtube in 1080p (you have to switch manually
                          It should play in 1080p. You have to switch the video qaulity manually. Try another full hd video.
                            Manually máx 720p......please help
                              null
