Will have a bit of a look see.
Startup burn works. but has some issues
Using Startup Burn
Attempt to place shortcut on lower part of screen near All Apps button does not work sits in nowhere land. Now ok
Netflix issue still there play Fine fights with lower menu
Cant play you tube loads in will not connect, I can sign in and out see vids to play will not play
Max 720 play option You tube can be selected.
As soon as you select hardware keyboard: Google play services Stop
And google play not logging in correctly if at all at time.
Went and did a product burn with the Tronsmart rom
Pretty much the same 2 1/2 hours in enough
Back to the gjayjayg\ boxx rom you tube fine. all is fine.
Today:
Back to Tronsmart must wipe unit make sure its clean no nasties left inside
I wiped unit and reloaded must always remember that, it helped but not 100%
Product Burn:
Google app store would attempt to update apps but just showed error on screen would not update
pretty much the same
Cheers
