JustMe ROMs v1.8 s802 AP6330 2GB
hello this is my first post ,first I would like to thank justme for his gr8 work ,most of the problems that I was running into mostly were addressed by others so thank you too ,I would like to mention that I come from 1.7 a just me rom the one before the latest release I did the update via the update app went all smooth and easy however i can not go back to recovery with any known method i even tried to put factory.aml and recovery image file from the 1.7a but no luck and tried toothpick method nothing happens can anybody help me how to accsess recovery so i can flash future updates thank you in advance.
Originally posted by Ericlupori View PostI don't have recovery on my m8 but I do have recovery on my gbox Q. Flashify can't be installed it says it's not compatible with this device and that is how I would flash recovery on the box is there another way to do this?
Originally posted by kokobsb
there is a way ,you put the rom which is .zip ending ,the factory file ending with .aml and recovery which is .img and image file ,you put all this on the sdcard then use the toothpick method but so far after installing 1.8 I cant go back to recovery no matter what I do its not going to recovery unless somebody from here can send me a working recovery file with 1.8 rom or explain what are they doing my box is ott m8 square 2 ,,....................,,,,,,,,,************DONT FLASH YOUR GBOX Q WITH ANOTHER RECOVERY**********you will brick it..
I have recovery on my gbox Q but not on my m8. So I put 1.7a back on the Q it's been a rock solid rom!!! I have bricked my Q and used guide on this forum to bring it back to life. Try factory recovery im sure it's in the forum somewhere.
Originally posted by cjeman View PostM8N install went well, as the rest of JM's prior ROMs.
Initial findings:
1) Custom Remote App worked.
2) CyberGhost loads and protects.
3) Audio output to both HDMI & SPDIF is a nice touch.
4) Cannot reboot into Recovery by either Application (Quickboot) or by toothpick method.
5) Cannot write to SD Card.
6) Cannot uncover the bottom toolbar.
Not being able to get into recovery locks the box. Not a big issue at this time.
you guys are welcome .the only reason I suggested not to put the factory-update.aml file is because the 1.8 didn't come with it that is why if you put the 1.7a .aml file it will erase the 1.8 to factory default but if you want to go back to 1.7a you put the 1.53d recovery with 1.7a .aml file and 1.7a update.zip.
Look so cool, I want this rom so bad. What do I need to do ? Here is my email = [email protected]
Originally posted by tineprogramming View PostLook so cool, I want this rom so bad. What do I need to do ? Here is my email = [email protected]
Originally posted by johno21 View Posthi, does this ROM support the vidonme code in the SDK to support 3d bluray iso playback in Kodi?
There are currently 3526 users online. 0 members and 3526 guests.
