JustMe ROMs v1.8 s802 AP6330 2GB
    Gave it superuser access? If you do then reboot and test the standby button.
      It's not prompting for access, and is not listed in SU.
        Will this work on a armada mach 8 box?
          JustMe =JustMe;n513079]Some updates to your questions guys hopefully the one not listed as sorted I hope to fix soon
          @DY59
          1) No Sound, tried the different out-put setings ( HDMI Passthrough, SPDIF, PCM , No USB Audio) with an HDMI cable and still not working
          (a) Can some else test this and verify
          2) There is no power button on the task bar with options to sleep the box. Box will power on/off with the power button on the
          button on the remote or with CEC to the TV , but does so from a cold-start not sleep.
          (a) Fixed the menubar down the bottom - power wake up is work in progress worse case senario you can use wake me up scottie app i created.
          3) CIFS mounts to an empty folder still (I use an app - CIFS Manager) .
          common problem as noted here
          (a) Will look into this soon
          @TD
          1. How can I remove the icons was added on "Add to Common.."? - sorted this
          2. How can I remove the apps icon was added on "Kodi Media center"? - sorted this
          3. How can I add the city, state to weather? sorted this
          These is couple issues founded
          1. No highlight on ethernet symbol (top/right), after RJ45 connected, but WiFi does - sorted this
          2. Disabled but bottom status bar still appearing...@Main display - sorted this
          cjeman
          5) Cannot write to SD Card.- looking into it
          6) Cannot uncover the bottom toolbar. - sorted this[/QUOTE]
          @ JustMe
          Any new bugfix FW v1.8 release near future..?
            I've donated to get access to this rom but can't see a download link after I've logged in, I missed a registration email that went to my junk mail and when I click on it says expired what should I do
              @JUSTME
              Any new build (Bugs fix) for 1.8????
                TD- their is new rom almost ready to be rls - been trying to get on top of things lately with custom roms, usual members rls.
                some news for you also TD - 15.2 - Amlogic chipset there was a change in firmware that caused Kodi to not function properly and only show a zoomed in or only used part of the screen.
                Bugs are Sons of Glitches!
                JustMe
                  @JustMe
                  Thank you so much......! (My self and family planning to travel to AUT, wish I can see you there in Chinese New Year coming up)
                    Hello I've deleted the Latest Rom and have been on the JustMe website and opened a Ticket asking for the Rom to be sent again but i'm getting no reply. Could someone please point me in the Direct so i can either get the Rom sent to me or tell me the link to download it. Thanks
                      Originally posted by dy57 View Post
                      Hi JustMe,
                      Just install this on top of JustMe1.5v3d on my M6 V.98 box ( one of the originals) and notice few issues:
                      1) No Sound, tried the different out-put setings ( HDMI Passthrough, SPDIF, PCM , No USB Audio) with an HDMI cable and still not working..
                      common problem as noted here :
                      http://forum.xda-developers.com/show....php?t=2106480
                      Anybody with solutions or the same problems?
                      Going back to V1.5 for now...
                      Also installed on my M8 box, ran all day perfect. Left box on then noticed it has sound, but very VERY low. Tried all the different sound output settings with no success
                      Last edited by brett2016; 10 September 2015, 03:20. Reason: Additionally: Did a reboot, swapped hdmi cables...no solution
                        maybe next rls in couple of days will fix this
                        JustMe
                          JustMe
                          Please, support S812 on next release......!!!
                          I am still using 1.7a (Last release 1.8...Doesn't work for me....), any exactly date for next release?
                            @ TD I will be releasing 1.9 first with newer sdk also fixed a few issues from 1.8 doing final touches s802 and I will start to upload tomorrow been long over due.
                            . s812 is on the cards next after this s802 rls, I think it's time for one
                            JustMe
                              Will this work with the total revolution mk 1 box ?
                                Sounds wonderfull , thanx for you hard work mate...
