Lollipop - Wasser Firmware for Tronsmart R68 with 100M LAN
    version 3.1.2
    • fix netflix issue (it hangs during playing video)
    • add support 1080p60fps youtube
    • fix usb sound issue, microphone issue
    • add sleep, reboot into recovery, reboot into bootloader in menu
    • fix some isssue in launcher3 and improve system performance
    • improve UI and video streaming
    • improve WiFi speed
    • update google apps
    Firmware download: wasser-firmware-lollipop-3.1.2-r68-rk3368
    Wasser Kodi-15.2rc2 (auto refresh rate switching, rockchip codec, passthrough) download: wasser-kodi-15.2rc2-lollipop
    version 3.1.1
    • add netflix support
    • add google play movie support
    • fix read/write permission for storage
    • improve IO performance
    • set 100% display size by default
    • fix some random crashes
    Firmware download: wasser-firmware-lollipop-3.1.1-r68-rk3368
    version 3.1.0
    • built from lollipop 5.1.1 SDK
    • firmware based on release-keys instead of test-keys to improve app compatibility
    • rooted
    • unified storage (emulated SD)
    • youtube 1080p support
    • init.d support
    • multiuser support
    • nfs filesystem support
    • exfat filesystem support
    • ir remote full support
    • add hardware keyboard menu
    • add longpress menu key to show/hide navbar
    • add power off button in navbar
    • add support "dont wake up devive with mouse movement in suspend mode"
    • add new mouse pointer
    • fix wake up issue in sleep mode by the stock IR remote
    • fix random ethernet MAC adress
    • update busybox
    Firmware download: wasser-firmware-lollipop-3.1.0-r68-rk3368
    Kodi-15.1 (support auto refresh rate switching) download: wasser-kodi-15.1-lollipop
    Updating instructions, updating tools and drivers download: flashtool
    Please report feedbacks so i can improve it in future release. Thanks
    Be aware: it is your own risk!
    wasser
    Retired ROM Developer
    Great work - Just got my box last week (Just the Pro unfortunately) and the stock FW seemed surprisingly good. I'm not a demanding user but I got Kodi running nice and smoothly in 30-40 mins.
    But 'root' is essential for my long term use and so I'll load this baby up tonight and try and give you some feedback. Anything in particular (high bit-rate MKVs, HEVC files etc) you'd like us to use to stress test it for you?
      Neflix running ?
        netflx doesn't work atm. I'm still working on a fix.
          wasser
          wasser What should I use to flash it? The FactoryTool gives me an error when loading the firmware.
            Originally posted by DiZet View Post
            wasser
            Updating instructions&updating tools&drivers downloading links:
            http://www.mediafire.com/download/7j...hing_Tools.zip
              I still get a load firmware failure.
              Also tried to load it into AndroidTool 2.35 and get the same error.
              It does however load into the Firmware factory tool 5.0, so structurally it must be fine.
              bluesmanuk
              FREAKTAB WIZARD
                wasser
                wasser Yes, those are the ones I was using. Gives an error when mounting the firmware. P.S. CanĀ“t wait to try it out
                  it's strange why it doesnt work under windows. Maybe it's a bug in windows tool. I only use linux tool to flash the firmware. It works fine for me with:
                  upgrade_tool uf wasser-3.1.0-r68-rk3368_box.img
                  please try to flash it under linux
                  Wasser
                    No linux here
                      I got it to work with the Windows tool.
                      Unpacked and repacked the image with the Firmware factory tool 5.0 to create a new image and now it loads into the flashing tool and flashes correctly.
                      bluesmanuk
                      FREAKTAB WIZARD
                        I did the same earlier and was able to load it in to the Factrory tool and flash it but did not get passed boot logo. Did you use Factorytool to flash it ?
                          Yes I used Factory tool 1.39 to flash and it worked perfectly.
                          Using the ROM now and so far,so good.
                            Strange. Tried it again and I get stuck on the boot. Can you share the compiled image ?
                              Sure.
                              I don't see any problem when flashing it.
                              https://mega.nz/#!H8BxDZrK!LUpnDmXmO...7EPTXu1rBTfjvk
                              bluesmanuk
                              FREAKTAB WIZARD
