I've the 2GB 8GB box..
Lollipop - Wasser Firmware for Tronsmart R68 with 100M LAN
Originally posted by lonix View Postis CEC supported in this rom for newer devices?
Originally posted by robot20 View PostHello I'm currently waiting for my device to come in. I went through the upgrade instructions. Ive upgraded from Windows 7 to windows 10.
Should I install windows 7 drivers or windows 8. I'm assuming windows 7 is correct.
Just run the driverinstall.exe from driver assistant 4.3
It does all you need for Windows 10.
Originally posted by Sergey-99 View PostAfter the firmware update is not working wifi, Bluetooth((
On Beelink? I got this one: http://www.gearbest.com/tv-box-mini-pc/pp_211700.html
Will the firmware work on this? I am eager to try out refresh rate change and working netflix.
There are currently 1496 users online. 1 members and 1495 guests.
