So based on your links, I'm guessing I just need a standard micro USB > USB cable and not an OTG cable (even though I'm using the OTG slot on the box)?
When I plug the USB cable into PC and Box... I put a pin in the reset hole and then plug the power cable in, but the box doesn't power up until I press the actual power button - not sure if it's meant to boot up straight away.
I've tried it with different usb cables I found lying about and also different USB slots on PC (tried my USB2 slots as well as USB3) but it's possible they're all crap.
If I fire up the box with it all connected etc, I don't get anything in Windows - not a thing. No USB connected noise, not even a flicker in the Device Manager to show something was connected.
Pulling my hair out at this stage.
