Lollipop - Wasser Firmware for Tronsmart R68 with 100M LAN
Originally posted by lonix View Postjust flashed it, LAN does'nt work
http://freaktab.com/forum/tv-player-...th-gigabit-lan
Originally posted by wasser View PostHi all,
lollipop wasser firmware version 3.1.2 is released. For more infos, please take a look at the first post.
Enjoy and don't forget to post feedbacks
Thanks,
Wasser
Wasser, thank you for you time and job.
How to update your firmware without to start from zero? Maybe you can create an update ROM option inside of your firmware.
Thank you
Miguel
Originally posted by bluesmanuk View PostMy feedback: for 3.1.2
Smooth UI and general fluidity of usage although when selecting apps to swipe off the screen there can be quite a delay before seeing them appear at times.
WiFi/Ethernet speeds as for the stock ROM.
Youtube/OGYoutube 1080p not good. Continual stutter which is not really watchable. Youtube Kodi addon works very well though up to 720p.
SPDIF playback works with 5.1 and DTS through MX Player and Internal video player and so far unable to find any flaws at all.
MX Player does seem to have issues with HEVC .TS files though, where there is major lag (no such problem in Kodi)
Kodi 15.1 RC1/16 Alpha 2/15.1 Wasser works well on the whole. SPDIF passthrough with 5.1/DTS still an issue with only the odd second of sound every few seconds(PCM/AAC all fine though). Frame rate switching, although working, is very slow to change in 15.1 RC1 and 15.1 Wasser which means losing a second or two of the initial video and audio.
Colour reproduction, although very good is not quite as good as I see on RK3288 and most noticeable in iPlayer where the picture can look very flat and almost cartoonish, so ideally, some contrast, brightness controls would be useful.
I have built new wasser kodi 15.2rc2 which should fix the passthrough and 4k video streaming. It's a big improvement in this version. Please take a look at the first post to get the Download URL
Please test it and report the feedbacks
Youtube works fine for me, no stutter. Maybe you should check your network!
Initial test had a split second of audio and then nothing from any file.
Second test had AAC working but silence when playing 5.1/DTS and the receiver showed no Dolby output.
Third test though had flawless playback of all sound.
All I did between each test was exit and start Kodi again but it is working a dream
There are going to be a lot of very happy people today.
The only issue I have is that it still takes around 6 seconds for any frame rate switching to kick in.
Guest
Thanks,
Wasser
Guest
i uploaded my firmware for beelink i68 with Gigabit lan, please take a look at this
Sent from my HTC One using Tapatalk
I just installed your newest verson 3.1.2 and everything is working that I have tested so far. My mic works and my Google accounts sync. I also installed your latest Kodi, but it doesn't have the PVR addons, but it does give Dolby and DTS passthrough with HDMI connection. Perhaps someone that is running your latest kodi will check to see if they have the PVR addons.
thanks. Great rom so far.
I installed the latest Kodi 15.2, had to uninstall your version, and it has the hickup every 3 seconds. I tried to install your version over it, but it won't do it. So, I can't use your Kodi version, because it does not have the PVR addons.Last edited by clarkss12; 10-06-2015, 15:23.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostMy mic works and my Google accounts sync. .
Originally posted by aka22 View Postmy mic also work (mx3 air mouse) but only if i put the dongle in otg port , after 3-5 times using mic - air mouse and button back stop working and i have to restart box to get it working, the same problem on rk3288 with rc4 Wasser firmware, the rest is everything perfect, thank You Wasser.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1248 users online. 24 members and 1224 guests.
Most users ever online was 7,737 at 14:33 on 01-16-2020.
