Lollipop - Wasser Firmware for Tronsmart R68 with 100M LAN
Hey Wasser. I just flashed my R68 to Your rom because someone said this would fix the DTS MASTER and Atmos to work.
But it didnt..
I can not get the DTS MASTER to my reciver and i have set settings to Passthrough and also in the R68 meny i have set the output to Hdmi bitstream.
I have no problem With these exact files streaming from my Mede8er to my Denon x4100.
Kodi talked about adding atmos, but nothing yet at least.
Is this something you can fix?
Also- To get 4K from netflix is there some way to spoof this Device to be a nvidia Shield or something that Netflix will send 4K content to?
Many thanks for answer and solutions!!
Greetings from Norway.
Originally posted by veralynn View PostHey Wasser. I just flashed my R68 to Your rom because someone said this would fix the DTS MASTER and Atmos to work.
But it didnt..
http://www.cnx-software.com/2015/12/...os-in-netflix/
I installed QNet tv app in my box but when i opened up the app the key board control not opening up for user name & pwd.
Also the new version of app is crashing when i launch the app _http://getapk.eatuo.com:8082/apk/live_160111.apk in this box
The same app works fine in my friends MX Amlogic Box.
Installed the wasser ROM for my Beelink I68 today.
It's a lot snappier than the standard rom, but the extreme stuttering in the youtube app (the reason for installing it) is unfortunately still there.
Lost both bluetooth and WIFI, I cannot enable it anymore, rendering it into a 60 euro brick for me.
Does anyone know how to fix my wifi/bluetooth?
Hi
I have beelink I68 with software 100L (link to my beelink that I had bought:. When I upgrade software to 3.1.3 beelink stuck on wasser logo : https://youtu.be/g1QXSToLdxc. Only this firmware to Tronsmart 105L1 firmware for Orion R68_10/100Mb version improved problem with sound passthrough but DTS HD do not work and sometimes problem with sound glitch. Could you help me with this problem ? ThanksLast edited by trebor; 03-11-2016, 21:33.
There are currently 865 users online. 18 members and 847 guests.
Most users ever online was 7,737 at 14:33 on 01-16-2020.
