UPDATED 5_21 - Tronsmart t428 Android 4.1.1 - Finless ROM 1.4a
    UPDATE May 21 - 2013
    It was brought to my attention (thanks Alok) that I left out a setting in the build.prop file causing some APPs to not install due to not properly seeing the SDcard.
    I have fixed that and made ROM 1.4a.
    However for those that have already flashed 1.4 and don't want to erase you can update this yourself.
    1) Because you are rooted you can easily edit build.prop file and near the end just add this line:
    ro.factory.storage_policy=0
    2) Reflash system.img
    If you don't know how to edit build.prop then you can flash only system.img using the flash tool.
    Run the flash tool and uncheck everything except system. Do NOT erase NAND.
    Now just flash system.img over the old ROM.
    It should reboot and you will be back with no data loss.
    ___________________________
    Hey folks.... By request I have made a 4.1.1 ROM for you guys.
    I consider this a BETA TEST for now as I have made many changes.
    This time unlike my MK908 ROM I found the real 4.1.1 ROM with no changes or root.
    I used that. But I still want to thank Freaktab user: strauzo for pointing me to using this ROM!
    Thanks to Vondroid for keeping the original ROM when it was released.
    I like to use a unmodded ROM to start with! Just me... But that's what I like.
    ____________
    SPECIAL NOTES! If you read nothing else READ THIS!
    I have noticed issues when flashing from a 4.2.2 ROM and this 4.1.1 ROM due to kernel differences.
    It appears to setup hardware differently.
    THUS... when you flash from 4.2.2 to 4.1.1 after the flash the stick may appear DEAD.
    You would expect recovery to come up and format /data /cache etc. but it may not go to that step.
    If you do not get that, you got stuck. NO BIG DEAL... Just unplug, wait 10 seconds, and plug back in.
    Then you should see the recovery system format things.
    BUT WAIT... we are not done yet!
    After recovery formats, it will reboot and may yet look dead. The TV screen "may" show nothing.
    BUT trust me... it is booting but the HDMI hardware has no reinitialized!!!!
    If that happens DO NOT PANIC! Wait at least 5 minutes (so it can boot). If you do not you may corrupt the file system!
    After a good 5 minutes unplug again.
    Now plug in, and it should work.
    I have noticed this DEAD HDMI output when going between ROMs and kernels.
    Again, please understand this and don't come complaining your DEAD because you are probably not.
    The hardware simply needs a full power off to reset.
    ________________________________
    Features and release notes for my 1.4 Android 4.1.1 ROM:
    1) Rooted and SU and Superuser per my usual 4.1.1 ROMs.
    2) I did quite a bit of clean up to init.rc and other junk that this ROM had and came from.
    It was made for a tablet thus had stuff we do not need. I cleaned up as much as I could find.
    This was not something I did for the MK908 ROM. I learned more doing this ROM.
    3) I added a low level but very good busybox. It does not have everything but I like it for simplicity.
    If you want you can install a larger busybox from Google Play.
    4) Stock ROM was only 1 Megs of APP space.
    BUT you also have parameter file options!
    There are also 2gb, 4gb and 6gb options.
    Read below for how to change that in the flash tool.
    Realize if you use this 6gb option, internal SDcard will only have about 600 megs of free space!
    5) As always, full init.d support! If you do not know what that is... ignore it. For geeks that want to use it. It is there!
    6) I enabled location services. This is now in the settings menu. Tested and working with all APPs that use it.
    remember to turn off GPS as we have no GPS.
    7) This ROM does not have a built in "hide status bar"
    It also allows screen rotation in APPs.
    So I have added to APPs for you to use!
    full!screen which is a cool APP that allows you to control hiding of the status bar.
    Rotation Locker which will allow you to stop APPs from rotating the screen.
    8) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
    I am spoofing a Samsung device that will show almost any APP as compatible.
    Yuur device will show up in google play as Samsung device nopt a T428 or RKSDK! Understand this please.
    I also left the original build.prop in the ROM called build.orig.
    If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
    Then rename build.orig to build.prop.
    Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
    Reboot! You should be back to showing up as a Minis Nexo X5.
    9) This ROM does not have a built in power off.
    I added a reboot APP that will allow optional reboot options like reboot to bootloader (flash mode).
    Power off now works using this APP.
    10) USB mass storage support.
    Stock ROM this is set as a MTP device and there is no longer settings support to change it in 4.2.2!
    I modified build.prop to change it from MTP to Mass Storage as I prefer this as it gives removable storage
    for the external SDcard as well as internal SDcard.
    On boot up if your connected to a PC you will get a start screen telling you USB is connected.
    This is how a tablet works too. If you turn it on from this screen you will see your removable
    drives on your PC.
    I removed the USB on/off setting as it did not work at all so was useless.
    This is also why I changed it to Mass storage.
    If you want to change it back, just edit build.prop.
    Other notes:
    This ROM will probably not have Xbox controller support. I doubt it does.
    Let me know if it works or not as I do not have a Xbox controller to test with.
    RK Remote (RK Mirroring) is not supported in this ROM!
    This kernel does not support it and I have tried to get it working. I will continue to try later.
    DroidMote should work. But I do not own that APP so cannot test.
    Ethernet stick works BUT.... it's a little sticky to get working....
    For me I had to do this to get USB Ethernet stick to work.
    1) Connect with wifi at least once! Yes this includes connecting to Google Play and account setup.
    2) Turn off Wifi and reboot.
    3) Boot up and plug in your Ethernet stick.
    4) It should work now. Wait at least 1-2 minutes for Android to get synced you are on Ethernet!
    If not, leave it plugged in and turn ON wifi. Yes they both work at the same time!
    5) Now turn off wifi again after it connected. It should work now.
    Also Ethernet settings are under the BT settings in More......
    This kernel is small, fast and the reason is not a lot of drivers are included!
    So expect many Ethernet sticks to possibly not work. Mine did though.
    Expect USB audio devices to not work. Mine does not!
    Expect other devices where drivers are missing NOT to work!
    However, over time we will fix all this...... Or at least try the best we can without source code.
    For more information ALWAYS read the README in the ROM kit!
    Here are the links for Android 4.1.1 Finless 1.4a ROM
    ROM -> Tronsmart t428 - Android 4.1.1 - Finless 1.4a ROM (250 megs)
    Enjoy,
    flashing works without problems here.Lanstick,Asus k400r and usbstorage also working.
      Thank you very much for doing this, Bob !!
      Can I use Rockchip Batch Tool_v1.6 for this or do you suggest other software?
      (If so, would you mind to share the name/url link?)
      Thanks again !!
      PS: Great timing BTW, .....DHL dropped off our sticks here in the office 20 minutes ago
        Miracle !!
        I have many android mini pc, and this is the fastest rom ever that satisfy me in all. It seems to have a great tablet connected to the tv finally !!
        Xbox 360 controller wireless for pc working very well.
        DroidMote work very well. Even the middle button of DroidMote works without changing the keylayout as in the old rk3066 rom.
        The wifi is super stable !
        1080p videos with MX Player with no problems.
        Gameloft games working.
        After so many purchases finally I have the real Google Tv the way I wanted.
        Thanks Bob for this rom, is the absolute the best. And Bob you're the best !
          Bob! You're amazing.
          Two questions, though (my T428 hasn't arrived yet, so I can not test myself):
          1. Is the kernel natively 720p or 1080p?
          2. Does the ROM support NTFS mounts?
          NVidia Shield TV 2015 16 GB || Stock
          NVidia Shield TV 2017 16 GB || Stock
          Buy me a beer?
            Kernel is 720 native. I am going to continue working to "patch" it to 1080. I have tried a little and no luck so far. This kernel is compiled very differently than 3.0.36+ for RK3066. But I have not gevin up.
            It's the best way right now until we get sources.
            NTFS should work. It's been suppored in most Rockchip ROMs since ICS came out. So it should work!
            I have not test NTFS yet though.
            Before hooking up a disk drive or something, test it by formatting a SDcard as NTFS in Windows. Plug it in and Android should be able to use it natively.
              I could use some advice as the ROM Flash Tool 1.7 cannot see my TV stick.
              MY PC does, but the ROM tool does not.
              I read the instructions carefully...
              To put the T428 into flash mode the easy way:
              1) Remove any SDcard you may have installed.
              2) Connected the supplied USB cable from the device OTG port to your PC.
              It will power up and windows may detect the device. DO not worry about that. We need it powered up.
              3) In the ROM kit run the ROM FLash Tool.exe.
              4) YOu should see at the bottom it says "Found RKAndroid Mass Storage USB"
              If it does not say that go into settings and make sure that
              a) USB storage is turned ON
              b) Under developer options, USB debugging is turned off
              Unfortunately, all I see at the bottom of the ROM Flash tool v1.7 is:
              No Found RKAandroid rock usb.
              The stick has the LED light on on my PC (win 7 x64) sees it:
              I can browse its folders and under "Computer" is shows as "T428 Portable Media Player".
              Further, clicking on "T428 Portable Media Player" I see: NAND FLASH - 5.71GB free of 5.81GB
              and further clicking on that reveals 12 main folders etc. etc.
              So I guess my PC sees it, but the ROM Flash Tool does not.
              as I mentioned above, Under developer options, USB debugging is turned off
              and the USB storage is turned on (which I guess under 4.2.2 is under "USB" -> "connect to PC" (???)
              I tried to look somewhere else under settings to turn the USB storage on, but could not find any other setting.
              Any advice would be appreciated.
                you have to press and hold the resetbutton from the device while you connect to usb,after you release the resetbutton the romflashtool find the device. this has worked for me.
                  Yes he did not read far enough in the read me I guess....
                    You sir are a GAWD!
                    Netflix CHECK, Hulu CHECK, Stream Bluray rip CHECK nuff said. Thanks for an awesome ROM. Only part I don't like is the boot graphics even when I changed it, it still stuck around. ROFL anyways everything looks great. I need to buy a hub so I can test Xbox controller but I hear that it already works. Thanks again.
                      Is this different from the 4.1.1 by deadhp over at ArmTVtech?
                      I'm running the 4.1.1 from over at ArmTVtech for now because it lets me run Netflix and Hulu. My understanding is that it's the pre-release firmware that was made for the T428 but shortly before Geekbuying started shipping these out, there was a change to 4.2.2.
                      I'd be keen to try your new ROM if it fixed the HiDef video problem. I wouldn't expect it to do that if it's "unmodded stock" firmware.
                        Rotation locking and Reboot features
                        If you're using 4.1.1 you probably know about the rotation locking problem. I've found that the best app to fix that is "Ultimate Rotation Locker". It runs in the background and even starts up automatically when you reboot the device, which means that there is no more farting about and when you lock the t428 in landscape mode, it stays bloody darn locked in landscape mode!
                        Speaking of rebooting, I've discovered that in both 4.1.1 and 4.2.2 pressing CNTRL/ALT/DELete on a physical keyboard will initiate a full reboot. NICE!
                          Netflix,hulu,and crackle working...Bluetooth hid working.
                          Only thing not is es file explore on apk install I believe this firmware moved to the sd card in another location.
                          Anyways thank you
                            So I must be stupid I haven't been able to get mine into flash mode. I have held the button on the side and plugged in the USB and the tool finds it but when I select reboot to flash mode I get a prompt saying Device can not do switch, because it is not msc device. When I use your alternative tool I only get a green box on #1 box. Yes I disabled debugging and I'm guessing USB storage is connect to pc? It's checked. Also I'm on stock 4.2.2. Just got it yesterday. And in your instructions sounds like your talking about the mk808 on how to reset using the paper clip by the hdmi. Because I'm not seeing that only the big button on the side of t428.thanks for any help
                              When the stick is detected to the tool and says Fund rockchip usb in flash mode you don't need to reboot to Flash mode, only erase Nand IBD, and flash the new rom
                              My devices:
                              Gearbest.com)
