UPDATED 5_21 - Tronsmart t428 Android 4.1.1 - Finless ROM 1.4a
Originally posted by darrellr View PostTV Stick: MK808 // Tronsmart T428
ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
Recovery: ClockworkMod
Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
Phone: Samsung Galaxy Note II
ROM: Whompasaurus v4.2
Kernel: Persus
recovery
Originally posted by Spotopolis View PostProbably because the software and or hardware for the WiFi is borked. I have a Galaxy Note II, and while it doesn't support 802.11ac, it does connect to 5Ghz WiFi and will at least connect at a constant 150Mbps. My T428 Will only connect and stay at 5Mbps on 5Ghz. It wont start off higher and then drop. Just constant 5Mbps. Its sucky, while my MK808 connects on my 2.4Ghz band and stays at 65Mbps all day.
Originally posted by dc2royce View PostOff topic but o saw recovery listed in your signature. It's there a way to get clock work mod installed on t428?
You can install cwm generic for rk31 devices (the only bad is that it cant flash or format the kernel partition) or you need a modded cwm based in fun work with your kernel embedded. I made 1 for the imitoQX1 and works fine for me.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Re: UPDATED 5_21 - Tronsmart t428 Android 4.1.1 - Finless ROM 1.4a
Originally posted by Spotopolis View PostProbably because Plex is transcoding it into a proper format that Android doesn't have any issues with. Thats what I have been using on all my devices once I discovered it. There is also a PleXBMC plugin and Plex Skin that allows XBMC to play from a Plex server. It works well.
No clue, but I tried direct play and it still worked great, even before strauzo fixed things.
cwm
Originally posted by dc2royce View Postnot sure i understand. how would one install cwm on this device?
A standatd cwm img, only 1 problem, it can't format or flash kernel
For comparison, my Samsung Galaxy S3 connects at 48Mbps and gets decent download speeds, no drops, hangs or any other anomalies.
My AP (ISP issued, generally regarded as crap, will be swapped out for something else soon) is in the basement, and coverage throughout the house is generally good.
The stock ROM was unable to keep associated to my AP for longer than a few minutes at a time before dropping the connection and requiring a reboot or two to get going again...
Apart from that, everything else seems to work properly, albeit slowly. Youtube takes forever and a day to load/buffer videos, but when it finally gets going, it keeps going and plays till the end. Video output seems slightly sluggish and sound isn't always synced (but that might just as well be Youtube acting up).
I also tried Finless 1.5A (4.2.2) and wifi was way worse there than on 1.4A.
Not sure where to go from here, I just need a stable, always-working TV-stick. I'm willing to tinker with it to get it to that stage, but I'm not willing to jump through hoops everytime it boots to get something working. It will mainly be used by the wife to stream kids' movies and suchlike from Youtube and the local network to keep the kid entertained while we cook dinner etc., so this needs to Just Work(tm).
Any ideas, other roms/kernels to try?
Originally posted by csj View PostOh yeah, and another thing: I can't for the life of me get Norwegian input to work. System is set to Norwegian and input language is set to Norwegian too.
Originally posted by Molle View PostIf you're using a physical keyboard, you need to purchase "External Keyboard Helper Pro" from the Play store to enable Scandinavian input. I tried every trick I could find from Google to get Finnish input for free but eventually just gave up and went with EKHP. Works like a charm.
Thanks a lot!
Got wifi working better by moving the stick 10cm upwards... seems there's a black hole for wifi signals just where the TV's placed. Just my luck
Now I'm trying to get games working using DroidMote or my Xbox 360 controller, and neither work.
The Xbox controller is plugged directly into the T428 via the original cable, and it does absolutely nothing at all. Any hints on how to get that to work?
There are currently 2089 users online. 3 members and 2086 guests.
