Amlogic S905 MXQ Pro Android 5.1 Lollipop TV Box Quad Core 2.0GHz
    Originally posted by rocketsbay View Post
    Hmmmm OK, do you think we can try to short cut the pins on the board as is mentioned with some amlogic TV boxes? Otherwise how will you try to flash the firmware?
    1. You can burn with USB Burning tools and USB cable in USB4 on rear side.
    2. short 29 and 30 pin on NAND IC
    but without right image it does not make sense
      Ok I get it.
      I have a second working mxq pro but don't know how to extract the firmware and couldn't find a tutorial on the internet.
        http://chinagadgetsreviews.com/downl...-tv-box-3.html
        http://blog.geekbuying.com/index.php...date-20160201/
        img - https://mega.nz/#!LAImAZbS!VNk0lQ8OX...tKLy5VDqa7Yt44
        box start, but i have no remote control
          can anyone download and share this file https://mega.nz/#!1xwAjb4A!X4c2N3Rov...-pyi8cmoWBA%20
            I have exact same model.
            1. There is no Bluetooth on this device. At least on mine I can not enable it. USB Bluetooth dongle does not work too.
            2. Kodi does not run 1080p resolution.
            3. Kodi does not play videos in full screen. Kodi Clear Data, Clear Cache, Uninstall, Resinstall of Kodi and Factory Reset does not solve the issue.
            Anyone experienced similar issues?
              yes, the same problems
                Does anyone find a solution to power off this device? I can only do it by unplugging the power.
                  There are few hardware different models of "MXQ Pro" ! You have "MXQ Pro 4k", and this firmware is for "MXQ Pro Quick Play".
                    Are there any MXQ Pro 4k specific firmware?
                      Originally posted by JustMe View Post
                      I have early jan mxq pro firmware if people want me to upload and also late decembers 2015
                      I can realy use it!
                      My box has all kinds of sound issues in Kodi, i'm getting almost crazy trying to fix it!
                        You have to ask your seller for new firmware.
                          I have the MXQ Pro 4k. I had a lot of sync issues in Kodi. Most of it i now sorted out, with adding permissions for amcodec with SManager. Everything plays fine. Except a few files, i put the information below. There is a serious audio sync problem. Anyone know how to fix this last issue? Maybe add another permission that is new except the ones given here https://www.google.nl/url?sa=t&sourc...CzB06CGx1wW2qA ? I use kodi 16, other versions have more issues.
                            Beter quality: https://www.dropbox.com/s/vgl7a46aor...706-1.jpg?dl=0
                              Can't really help you, but how do I root the Mxq Pro 4K? Easiest way preferably. I am an android noob. Thanks in advance.
