Amlogic S905 MXQ Pro Android 5.1 Lollipop TV Box Quad Core 2.0GHz
    I have two identical MXQ Pro 4K boxes which came preloaded with android 4, Kodi and a bunch of other apps. Once they were hooked up and powered
    up they installed Lollipop 5.1 and seem to work rather nice except for one annoying aspect - I can not access a USB stick to back up to. No matter which slot
    I use, and I tried 4 different USB flash drives on both boxes - I always get access denied. The flash drives are fine and NOT in read only mode. This is starting to look like
    a firmware issue. Anyone seen this issue before I start to go back to the seller? I really don't have any complaints but the lack of USB support - especially since there are 4 ports,
    is a deal breaker for me. All Kodi apps related to backing up to USB fail because of this too. Any thoughts are appreciated! Thanks!!
    MXQ Pro 4X, Andriod 5.1, Lollipop 1G/8G Amlogic S905 Quad Core
      Hello,it no box issue ,i have same problem as u before ,i cannot save my file to sd card using kodi ,after some found this couse the problem with android 4 kitkat ,
      Go play store found app call sdfix or similar app to fix it.
      Hope it work for u
        Originally posted by NelisR View Post
        Which firmware do you use?
        i'm using the stock firmware with kodi 16.1 rc
          if there is a better and stable firmware out there for this box by all means someone please share it through a better site. thanks in advance.
            New firmware here.... http://chinagadgetsreviews.com/downl...l#comment-2854
            UPDATE LINK (error link) http://chinagadgetsreviews.com/downl...v-box-2-2.html
            I succed to update with a good version of Cd burning rom (put image in licence directory to avoid "key failed")
            Don't notice any change....
            I still have an issue with external_sd path to use SPMC with data on external SD.
            Regards.
              Regards.
              so there is no change? if no change, im not going to do it. thanks anyways
                No visible change to my eyes... but it will be better to have a changelog
                Use this link ... http://chinagadgetsreviews.com/downl...v-box-2-2.html
                  Any chance of detecting if its a clone or genuine MXQ PRO BOX??
                  Sent from my GT-I9505 using Tapatalk
                    OpenElec version for this box here .... http://amlinuxmedia.com/forum/index.php?topic=27.30
                    Kamik is the dev of that release, and Kerber helps him
                    For now, OE is fast but not still stable... many freezes for now... to follow.
                      Recieved MXQ PRO 4k p201 today with 201603 firmware LMY47V and 201603 kernel 3.14.29. Iminix_u1_ez_root succeeded. I notice this is 32bit software (albeit 64bit hardware). First impressions are good. I see plenty /data/system/dropbox/system_app_crash@*txt generated by process com.google.android.gms though.
                      Is OpenELEC S905 64bit?
                        Can you check cpu temp via cpu-z app?
                        Free 100Gb space for your files:
                        https://degoo.com/g/Ov7nAz0
                          42
                            Just 42 C?
                            I have Ki with S2+T2 S905 and temp is 70-80 C.
                            Sent from my HUAWEI MT7-TL10 using Tapatalk
                              Just 42 C?
                              I look in sys
                              # cat /sys/devices/virtual/hwmon/hwmon0/name
                              aml_thermal
                              # cat /sys/devices/virtual/hwmon/hwmon0/temp1_input
                              42
                                Anyone has any solution for bluetooth?
                                No bt dongle works.
