[ROM] SC_V1.2 Custom Rom Beelink X2
semoGx2
If you want the 5.1 channel for local movies try this.
I installed MX Player with AC3/DTS codec, but i have not a equipment to try the 5.1 channel.
But if you want try this tutorial and tell us if works and i have not sure but i think you should modify some issus in the Android settings
http://forum.xda-developers.com/apps...pport-t2156254Beelink X2 and Nexsmart D32 for now!!!
Tried that and didn't work.
MX player cannot make passthrough ?
Please tell me what I'm dong wrong?
Unable to boot/install OrangePi PC with Beelink X2 V1.1 (or V1.2)
Flashed V1.1 with two different 16 GB microSD cards. On version shows me the red rectangle on black screen and stays there. The other card boots up in Google TV Splash screen and stays there.
Flashing V1.2 gives me the red rectangle with some distortion above the rectangle.
Using Phoenixcard 3.10. Tried different micrSD usb card holders.
Tried whiping partition and format with SDCARDFormatter.
Power supply is rock solid 5,1 volt
CPU has Cooling fan.
This is a new Orange Pi PC.
Installed the OPi Plus 2 with the Beelink X2 version the same way and that worked fine. (although I had to try multiple times.) Formatting with phoenixcard is not very consistent.
Even when it completes the burn.
Please help!
There are currently 2698 users online. 0 members and 2698 guests.
