[ROM] SC_V1.2 Custom Rom Beelink X2
Extract from zip recovery.IMG file,
rename to twrp.IMG,
copy it to SD card.
Get from the Play Store Android Terminal Emulator.
Run the terminal emulator APP.
type su
Agree to the super user prompt
Now type: dd if=/storage/extsd/twrp.img of=/dev/block/by-name/recovery
The terminal will do it's thing and should come back with no errors.
TWRP is now installed.
Originally posted by superceleron View PostYes that it the bug, but you can fix it
Sorry m8 i only removed all their protection crap... and fixed the sound output to work on other roms.
Fix you only need to do it once:
1º disable the AW codec
2º put the movie/video playing and pause it and open the aspect/interlace etc(to the ppl that dont know is in the control bar) put everything as you want(on my tv i always put as stretch 16:9 )
3º tick "Set as default to all videos"
4º close, un-pause the video see if that is how you like it, close the video.
5º activate AW codec and voila fixed
Maybe i upload it to my github account.
Thanks in advance.
There are currently 2874 users online. 0 members and 2874 guests.
