[ROM] SC_V1.2 Custom Rom Beelink X2
    Originally posted by tiagoggama View Post
    I install Sc_v1. 2 ROM, and after that, the beelink x2, always freezes on boot. Won't pass the superceleron text screen. Please help
    Sent from my UMI TOUCH using Tapatalk
    Flash back the stock rom...
      I have the same problem , I have two X2 H3 and both freeze on boot, i flash back to beelink stock rom but same problem, I flash it several tiems and onlky works with Trosmart Draco H3 rom, but not ethernet and not remote.
        well is hard to know where is the problem without having one with that problem, it can be a lot of things... but it odd that only 1 rom work...
        The tronsmart draco rom diference to the other its missing the eth. and the clock freq. are lower for the stick not to overheat.. so maybe this is your problem overheating.. dunno.....
        Sorry!
          First, thank you very much for your effort to help our small community. We all appreciate your hard work.
          I need setup my USB keyboard (wireless), for that I need modify the qwerty.kl file, I do this but the system don't get the new changes.
          Please help me.
          Wich one file QWERTY.KL use for the system?
          Thanks in advance.
            Hello
            I try use this rom and get freeze on second image,
            Phonixsuit V1.10
            now I cannot get work any image if don't have SYSRECOVERY
            please help to install this rom
              Thanks for this custom ROM!! Awesome stuff. It is mainly working, but wifi is not turning on upon booting into the ROM. Anyone else experiencing this?
                Hi anybody have khow to do this box start (boot up) self just on ac adapter, no button needed push requered???self started
                and how to install external antenna... please...
                  Is Phoenix Suit the only way to install the image? What kind of USB cable do i need? A cable with a large USB rectangle head on both sides? I dont own such a cable, generally usb cables that connect to the PC have a little microUSB plug on one end and then the large USB head to go in the PC. This is really confusing to me
                  Sorry for the noob questions. Wish there was a sticky on PhoenixSuit.
                    If there is a way to install this using an SD card please advise me and please post a link with instructions or advise the name of the android app that I would need
                      I have the same problem as two others on this page. I can't flash a working SC ROM. I tried all 3 files multiple times. All just stuck on SC boot text screen. I believe the first time this screen shows up, the software must be formatting the rest of the 8GB storage, but something fails? This ROM works great on Orange Pi PC and One, and also on the Beelink if you boot it from micro SD card. There's just something wrong with installing it internally. The Draco H3 ROM flashed no problem.
                      Also, for the Orange Pi people looking for Wifi adapters, the SC 1.2 ROM supports specifically the RTL8188EU dongle.
                        I received from factory the https://drive.google.com/open?id=0B3...mMyLVNyazZmdEE the last version will work to
                        RTL8189ETV i dont know if will work on older wifi chipset AP..... But this version is realy soft work fastar, wifi ok signal ok....
                        to root super su work fine
                          herr_marechal, Thank you for link to the new firmware.
                          I will give it a go.
                          Cheers
                          Kevin
                            I successfully flashed superceleron v1.2 rom to my beelink x2 using phoenixsuit 1.0.6. I then tried to flash retrorangepi using sd card and despite getting success for sd card process, when loaded I got a horizontal orange line. At this point, booting 1.2 rom was no good. I tried reflashing with phoenixsuit, which said update was available. I updated to 1.0.10 and flashed, which I think now was mistake. When plugged into computer with usb, I can get to turn on, but does not turn on when plugged into tv and gets no signal. Recovery toothpick does not seem to work at tv, only to recognize at phoenixsuit. I reloaded 1.0.6 and flashed, but that did not work. The retrorange pie causes it to turn on at tv and provides signal but just sits there. Any thoughts on if I can get in recovery.
                              hi, have a way to install this rom with the sd card? i don“t have cable
                                ^ Search for a program called "PhoenixCard", possibly also a program called "Etcher" might work.
