[ROM] SC_V1.2 Custom Rom Beelink X2
Originally posted by superceleron View PostJust use "es file explorer" enable root and edit the build.prop in /system
No theres no firmware check, maybe that app that tries to change the build.prop just screw it!
And yes the sdk is very bad with kodi... even with the custom onecant do better :/
I managed to get the uverse app working by faking a nexus 10 in the build.prop. Now my problem is that the uverse app checks for root and limits programming because of that? Root hiders don't appear to work.
Ey supelceleron, is your ROM still kodi wide better than the "original" X2_203K4 (2015 11 Nov) ?
I need to upgrade koi to 15.2, so I can restore all of my kodi add ons and settings I've previously backed up from another android box... Can I do it with yours?
Cheers and thank you for your work!
Originally posted by Dankex View PostAlready using yours, but never actually tested the box with the new original firmware, not even the default one. How can I upgrade kodi with your firmware? Can I simply download it from Play Store? I won't use anything above 1080.
Originally posted by DaremoS View PostI succeeded installing a new version of the firmware (X2_203K4), next will be to install your ROM... but first I'll do another backup using TWRP 2.8.6 H3 which I flashed again, as updating remove it.. That was the only stuff that was removed. I don't like installations from scratch, except for special situations,. In this aspect I like very much Rckchip devices, which are more polished updating also AML powered device are so tricky when is comes to do some update.
The problem was how bad implemented is PhoenixSuit. I recall that I had a an Ainol Novo 7 Aurora tablet, powered by Allwinner chip. It suffer of the same problem. It never shows that your device is correctly installed, then it's needed to install using "brute force" bt pressing key many tiemes pressing key and all that silly procedures.. happily it offers upgrade with format or just update.
BTW... I've mange to install Kodi 15.2 with all the stuff which is needed... that another tricky task... but happilly is very well documented. That wasn't lost in the upgrade.
Anyway super... thanks for your clues again.
DaremoS could you please be more specific what did you do ? I have exact the same problem! There is a exclamation yellow sign USB Device(VID_1f3a_PID_efe8) (device cannot start).
What i have to do in order PhoenixSuite recognize device?
Thanks in advance!!!
I really want to fix "red light" cannot start device with this firmware.
Btw: i soldered on my own type A male to male USB cable. Maybe is there a problem? How could i check if cable is ok? Thanks in advanced!
Brgds,
SeroLast edited by sergejk; 18 December 2015, 08:48.
Originally posted by superceleronNo kernel driversorry but now i cant help already packed all my stuff for this device.. :/
Too bad, because it is very nice and well built ROM!
At least, here I got some answer, on orange pi forums there is no activity at all... :/
There are currently 2084 users online. 1 members and 2083 guests.
