[ROM] SC_V1.2 Custom Rom Beelink X2
superceleron Zidoo released kodi 15.2 for X1. Can you modify so it works on X2 H3 please
Sent from my GT-I9190 using Tapatalk
superceleron , using your ROM and installed your custom Kodi 15.2 with latest librtmp, but looks like kodi crashes every time I stop any PLEXUS stream or any other Live TV stream... It sometimes also suddenly stops for no reason at all... Any idea why ?!
Yes, Im using your custom ROM. Will search for that plexus bug...
Btw, any recommendation on tweaking advancedconfig file for a better buffering mechanism? Always used OSMC on my RPi, so never felt the need to config this... What should be the default values for this amount of RAM and disk space?
Hi there. My beelibk x2 came today. I updated to the latest firmware via online update tool. I only needed this device to play h265files and they are playing yes but it seems it can't play hevc 10bit h265 videos.. It does not have hardware decoding for 10bit videos. Am I right ? I also tried with mx player and the same results. Do this rom of yours can somehow improve this situation , I mean you are using custom hardware acceleration here right ? Does it maybe enable for 10bit hevc hardware decoding too ? This is my only problem right now.
Originally posted by superceleron View Postif you are using the kodi that comes with the com ( 14.2 ) is already config!
Check the file Android.tar in "system/media" there is the advanced settings you need
There are currently 2218 users online. 1 members and 2217 guests.
