Tronsmart Vega s95 Amlogic s905 Series: Pro, Meta and Telos
I would flash the latest, many bugs were reportedly addressed with it.
Images for Flashing via PC are up for the Telos now, the Meta and Pro will probably get posted today.
If you have trouble, I have the steps I took posted over at the Tronsmart forum.
For now, I am signing off. I'll check back this evening.
Good day.
Originally posted by RISCy Dude View PostI would flash the latest, many bugs were reportedly addressed with it.
Good day.
Originally posted by feelulive View Post
Will be telos pluged to power adaptor
If you attempt to update via PC and the box just boots to desktop, you may need to follow the steps I posted on Tronsmart's forum.
Here is an excerpt of the relevant parts...
-Box hard off(no power LED)
-Starting with S95 LED off and disconnected from PC
-Open USB Burning Tool
-Load image
-Press USB Burning Tool Start button
-Press and hold S95's Fn button(reset)
-Connect USB Cable, keep holding the reset button until the USB Burning Tool shows connection."
Originally posted by RISCy Dude View PostThe Telos has different power requirements than the Meta and Pro, 12vdc vs.5vdc, owning the Meta, I cannot say if it should be connected to supply. The Meta will boot entirely from the OTG port with no power supplied by the wall adapter. I have flashed under both conditions. In both cases, the procedure started with the power LED completely off, not red or blue. Since you cannot get your box to that state, I think you will have to start with power disconnected. Before doing so, remove all unneeded peripherals, i.e. disconnect USB accessories, remove SD card, disconnect SATA HD, etc.
-Load image
Originally posted by trebor View Post@feelulive the TV that has the Tronsmart is connected.
Does the TV have an external TV antenna connected or Satellite gear.
The power pack used on the Tronsmart is it in a power strip or directly in to wall socket.
Cheers
i use belkin power strip
Originally posted by blinkone View PostThe google play store still keeps crashing when using sixaxis app so still more work to be done
Also if you try & change the input setting to a Bluetooth keyboard google play services will crash
I have Got The same problem with sixaxis controller that crash Google play on my Vega s95 Meta so has anybody got an alternative to use dualshock 3 on Android games ?
Other question: other gamepads Like moga, xiaomi gamepad or tronsmart mars g01 can be used on emulators Like ppsspp.org.
Thanks.
Excuse my english i'm french
Originally posted by mclunaar View Post
Hello,
Thanks.
You can get it to work by uninstalling the updates to the google play services but then the play store ect ect will not work until you re update the play services again
The tronsmart mars G01 is ok & will work with most games but not all but should work with most emulators
I very much doubt that the sixaxis bug will be fixed by tronsmart so don't hold your hopes up for an update to fix it.
FOR customer who have google play store crash problem,suggest to do the factory reset, and some users on tronsmart forum said it help. And the main reason for causing the crash, should be root the vega s95, and change something. just give it a try.
Eric
Looking for developers
Originally posted by geekbuying View PostFOR customer who have google play store crash problem,suggest to do the factory reset, and some users on tronsmart forum said it help. And the main reason for causing the crash, should be root the vega s95, and change something. just give it a try.
Eric
There are currently 2141 users online. 0 members and 2141 guests.
