Tronsmart Vega s95 Amlogic s905 Series: Pro, Meta and Telos
Originally posted by mclunaarHas anybody got problem when updates library from vidon. When i do that vidon crashes immediately. It's update from smb. But i Don't know where the problem can be...
I just got mine Telos, and I cant connect to ext hard drive thag I have on share on my desktop Pc upstairs.
I have both connected through ethernet.
Vidon xbmc gives me an "invalid argument" when I try to add files to the library. (Files, add videos) I can se the drive, and shared folders but clicking to add gives that error.
Connecting through other pc or laptop with windows works perfectly.
Im loosing my mind as everything I have is on that shared drive.
Sent from my SM-N920W8 using Tapatalk
Originally posted by G-can View Post
I do.
Add Videos
Browse
Add network location down the bottom of the list.
Worked well, usually I just browse and they appear in other versions,
I found the same with Plex had to add ip, would not find share but i am guessing it is something
in Windows 10 causing this, have not looked further as yet.
I also see over at VidON they have a network server that may improve file handling for VidON.
Cheers
Originally posted by mclunaar View PostHas anybody got problem when updates library from vidon. When i do that vidon crashes immediately. It's update from smb. But i Don't know where the problem can be...
Maybe have a look in the VidOn Forum they may be able to assist.
Cheers
Originally posted by trebor
I found shares by adding IPaddress :
Add Videos
Browse
[ATTACH=CONFIG]n550602[/ATTACH]
Cheers
Hi guys, I am about to buy Tronsmart Vega s95 telos. If someone have it, can you please try game Forsaken World Mobile (https://play.google.com/store/apps/d...om.fedeen.fswd) and tell me how it works? It works well on s812 SoC with 2GB ram, but I need 16 GB of disk, thats why I am planning to buy telos version and s905 SoC.
Originally posted by DennisDee View PostHello RISCy, Indeed, it is same as on phones. Same amount from written is reserved for OS. Just need someone to test for me please Forsaken World Mobile. I am in doubt what to buy, MXIII or Vega s95 Telos
User on tronsmart forum reported me, that the game works on his s95 telos. He have installed Remix OS 2.0, as far as I understood him. Can someone else confirm maybe, that this particular game works? I don't need hard gaming test, just install, load game, try to move to check if game works smooth.
Thanks in advance
There are currently 2191 users online. 9 members and 2182 guests.
