Tronsmart Vega s95 Amlogic s905 Series: Pro, Meta and Telos
Format it to fat32. On NTFS there is LP bug, max write size is 10MB
File System Read Write NTFS OK No (10 MB free space) EXT-4 Not mounted Not mounted exFAT OK No (10 MB free space) BTRFS Not mounted Not mounted FAT32 OK OK
Read more: http://www.cnx-software.com/2015/12/...#ixzz3yMKeF15Q
Originally posted by DennisDee View PostFormat it to fat32. On NTFS there is LP bug, max write size is 10MB
Why the heck does system time keep reseting to some stupid time/date/year?!
Plus, I have an issue with picture cutouts, changed couple hdmi cables, even tried connecting directly to.projector, and still random picturr cutouts randomly for couple seconds.
Anybody had this problem? I have telos, rooted, but its been doing this from day one. Sometimes fine for days and then goes crazy
Originally posted by jeffskodi View PostHi,Does anyone encounter power off automatically after 5hrs of using the box Telos S95.It trip power off on quite occasion recently once On it Off by itself.Puzzle what could be the problem?Could be the firmware?
Originally posted by G-can View PostWhy the heck does system time keep reseting to some stupid time/date/year?!
I am curious, did you use OTA to update the firmware on the box?
Originally posted by kokobsb View Post
I think it's with only dts 5.1pass through with spdif the clicking problem .tronsmart is aware of it .vidon for sure and I think it's an amlogic problem.thanks .I use vidon .eheheh
Originally posted by nocturne View Posti have this issue too on mini mx 2gb/16gb version latest frimware. any solution? also kodi freeze if i change the movie.
Guys, i am new here, interested in the s95 meta, mainly for kodi streaming, web browsing and youtube. I am currently using a no-brand box, which has a lot of reliability issues - optical sound mumbling, green-pink picture, freezes, etc. Would you recomend the s95 to be reliable and issues free?
Also - my current box has an outer wifi antenna, and it has pretty good reception, would you say an inner antenna as the one of the s95 would be at least as good? And last - does any of you know beelink gt1? Which would you say is better and more reliable?
Originally posted by bluesmanuk View PostJust played around with WiFi settings on my router and saw that the 5Ghz channel is set to operate on the 80Mhz bandwidth, which, if I understand things correctly is required for WiFi ac.
Changing it to operate on 20/40Mhz bandwidth enables it to be seen by the S95 but I never had an issue with any other ac supported devices seeing the 5Ghz channel when operating on the 80Mhz bandwidth.
There are currently 2925 users online. 7 members and 2918 guests.
