However inside the plastic black box there appears to be alot of different mainboards and versions....which tends to make finding a "all working rom" a problem due to remote control and wifi chip differences from mainboard to mainboard.
SO..the reason main reason why I wrote this thread. Someone in the Openelec thread for MXQ said it may be a good idea to collate info on all different ALL BLACK MXQ's. This should hopefully help people to find a rom that works for their box (or aleast get it from a bricked state to recovery)
If you would kindly use the following template when posting. Please fill as much as possible:-
Version Marking on mainboard:
Pictures of mainboard:
Wifi Chip:
Known Working UPDATE rom:
Known working IMG rom (for USB burning tool):
Known working Openelec version:
Where puchased:
Any other info:
IF YOU FOLLOW ANYTHING ON THIS THREAD, YOU DO AT YOUR OWN RISK. BOARDS MAY HAVE SAME MARKINGS BUT STILL MAY BE DIFFERENT RESULTING IN BRICK RISK ETC.
Over on another Russian forum they have formulated a simular directory...but all in russian. http://4pda.ru/forum/index.php?s=&sh...ost&p=42704536
