MXQ "All Black" S805 Versions / HD18q / and Clones Directory
Originally posted by pigbait View PostI have a few Remote.config I will be posting later on
Edit: As promised these are remote.conf I found that have fixed most of my boxes with non working remotes.
https://onedrive.live.com/redir?resi...hint=folder%2c
hi i used remote 3 all working but the ok button does anyone have a fix for this??????
Originally posted by jed View Post
fanni2 So you can use it perfectly fine on Android, or wait for OpenElec support ("K" has identified whats needed) or return it, using the fact that it is a "Clone" from their own description. I noticed a lot of negative feedback for this very reason. Its mis-advertising as in effect they are all "clones" :-) Will the real all-black-MXQ please stand up ? No-one stands :-)
So my next question would be how do i use the info from my working remote.config to add into openelec???
Originally posted by topher67 View PostI have a "generic" black box mxq, supposedly from tayunsmart(?), brand MBX, model m201, usual spec except wifi module is reported to be RT8189ES.
Question then, does anyone know which of the openElec builds - or other ROM - would be good to flash?
Peace.
Originally posted by poul50 View Post
try this https://mega.nz/#!90pWkD6A!TSuLpNCsY...EBkXSNrR1PP4G4 it is not openelec but android
Is that a stock ROM?
Originally posted by Dc0de View PostVersion Marking on mainboard: S805_MXQ_V03
Pictures of mainboard: See attached.
Wifi Chip: Realtec but cant read the model number
Known Working UPDATE rom: https://cloud.mail.ru/public/9RUK/k5VWgv44G (based on MXQ_112k4) and is called MXQ_112k4_lite_Multi.zip as it does not replace Uboot or Logo. It says on the 4pda.ru forum that may work on other devices (universal). USE AT OWN RISK.
Known working IMG rom (for USB burning tool): https://cloud.mail.ru/public/7oSn/WunL7sMWW
Known working Openelec version: Yes see http://freaktab.com/forum/tv-player-...268#post541268 Bootloader.img needs changing to avoid brick. Do at your own risk
Where puchased: Amazon UK.
Any other info:
May be a clone, a later version of the HD18Q, or something else. I have tried about 10 different roms on this new box, including the *standard* openelec builds for HD18Q and MXQ (from Sdcard and Nand)....all result in a bricked box with no access to recovery via toothpick, no recovery via bootcard maker...Only way to recover was with USB A to A cable and USB burning tool with correct img file https://cloud.mail.ru/public/7oSn/WunL7sMWW which i found at http://4pda.ru/forum/index.php?showtopic=621980 . This firmware is marked as MXQ-S805-V1.2 (HD180_V1.2) and "for those with a brick and error when you try to restore [0x10105002] Romcode / Initialize DDR / Read initialize status / USB Control setup error" when using USB Burning tool....which is the error I was having when restoring any other img. Wifi works on this rom and so does access to recovery...Remote does not work. I do have a nandroid back up of the original (pictured below with a date of 11112015!!) which I will restore.
EDIT: Found an OTA update at http://4pda.ru/forum/index.php?s=&sh...ost&p=44636523 that works for this device. It says it doesnt change Uboot or Logo. See link above. Be aware first boot takes about 5-10 Mins.
EDIT2: Openelec now working after changing bootloader.img in openelec update zip (see above)
Now I share my version:
Version Marking on mainboard: S805_V03 20150816
Wifi Chip: RTL 8188_TV
Known Working UPDATE rom: Testing this one http://4pda.ru/forum/index.php?s=&sh...ost&p=44636523
Known working IMG rom (for USB burning tool): For me works very well this one https://cloud.mail.ru/public/7oSn/WunL7sMWW
Known working Openelec version: I try this one https://="http://s805.eu/releases/6....6.0.3.1.img.xz Wifi and remote OK
Where puchased: Mercado Libre Argentina
Any other info:
Hi! I unbricked my box using the russian .img, but I can see that you made a nandroid backup of your original firmware the one dated 11112015. Could you upload it and share?
Saludos from Argentina
Hi guys...need help foe a good firmware for my ott MXQ pls.. any known good firmware for this box pls that you have used and tested ....android or openelec pls....here are the details pls..thanks..these are the pcb bpard pics..my wifi chip is realtek rtl 8188etv..thanks..any help would be much appreciated..
Sent from my GT-I9505 using Tapatalk
Originally posted by warlock09 View PostHi guys...need help foe a good firmware for my ott MXQ pls.. any known good firmware for this box pls that you have used and tested ....android or openelec pls....here are the details pls..thanks..these are the pcb bpard pics..my wifi chip is realtek rtl 8188etv..thanks..any help would be much appreciated..
Originally posted by PatrickJBYou could try this: http://freaktab.com/forum/tv-player-...mk808b-and-mxq
Which one should.i use,nand..sd ..update..which version the latest one..6.0.3.1??any turutorials on how to flash.is it toothpick method as well to flash.?this the firmware on the ott mxq now..thank u
There are currently 3429 users online. 0 members and 3429 guests.
