MXQ "All Black" S805 Versions / HD18q / and Clones Directory
Originally posted by markedman View PostHow did you flash that? USB burning too(?) and if so, which version as I've seen several. OR, did SD card, or even USB flash drive work?
.img just format your SD card.. put the SD card in your box using the toothpick while plugging in the power. go here and read up on it.
If the Image from JD un brick wouldnt work on your device youll have to get one from manufacture. Or try the second method (Thats the biggest problem with these clones no stock firmware for device. )Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by CyrexZ3 View PostCan someone help me find a working rom for this board. I am able to get into the recovery but i just cant find the right rom files. I've flashed many roms via the recovery mode but they all give me a blank screen with a constant blue light sometimes red. I dont know if i did something right or i have the wrong files. If anyone know which files i need for my box please provide a link to the rom that would be greatly appreciated. Thank you.
Board Type : S805-v1.0-SDO-20151223 (as seen in the picture)
Wift Type : Realtek RTLB189ETV FA15H31 (too small to get a picture of but i wrote it down)
CPU Type : SKhynix H27UCG8T2ETR BC 511A BN15812HY (as seen in picture)
Pictures here : http://tinypic.com/a/97p838/1
Originally posted by fedejmz View Post
Hi! I'm new here and I unbricked my MXQ with the help of this post, THANKS!
Now I share my version:
Version Marking on mainboard: S805_V03 20150816
Wifi Chip: RTL 8188_TV
Known Working UPDATE rom: Testing this one http://4pda.ru/forum/index.php?s=&sh...ost&p=44636523
Known working IMG rom (for USB burning tool): For me works very well this one https://cloud.mail.ru/public/7oSn/WunL7sMWW
Known working Openelec version: I try this one https://="http://s805.eu/releases/6....6.0.3.1.img.xz Wifi and remote OK
Where puchased: Mercado Libre Argentina
Pictures of mainboard:
[ATTACH=CONFIG]n558830[/ATTACH][ATTACH=CONFIG]n558831[/ATTACH][ATTACH=CONFIG]n558832[/ATTACH][ATTACH=CONFIG]n558833[/ATTACH]
i Have MXQ s805 v3_1 20151230 i can get the usb burning tool to flash no problem with aml_upgrade_package_mxq_20151113 after it turns on everything loads. i have wifi. but remote wont work. when i upgrade to cyx_MXQ_8189etv_8g1g_kodi_addons_16 it will install then restarts and stays at Mbox logo. also the red light stays on. dose anyone have any images i could maybe try thanks
Warth7 tutorial for MXQ v3_1 20151230 RED LIGHT: USB Burning Tool V 2.0.5.15 Load Image (aml_upgrade_package_mxq_20151113) Might need to short pins thats what i did. After you get Burn Successful The hook up your box but no power!!! Very Important NO POWER!!! Then Get SD Card And Put cyx_MXQ_8189etv_8g1g_kodi_addons_16 using SD card Burner with the u-boot in that file. After that is done put it in the SD card Slot in your MXQ, Hold RESET Then plug in power. Blue Light Will Come On. Let It Install Leave It Alone. After Its Finished You Should Blue Light Back On. But mine Is stuck on Mbox Logo it restarted and its just like loading on mbox logo. but i do have blue light back this is testing only thanks. an info about the stuck logo and how to get around it would help thanks
There are currently 2060 users online. 0 members and 2060 guests.
