MXQ "All Black" S805 Versions / HD18q / and Clones Directory
    Originally posted by Dc0de View Post
    Version Marking on mainboard: S805_MXQ_V03
    I do have a nandroid back up of the original (pictured below with a date of 11112015!!) which I will restore.
    Would it be possible to get a copy of that backup. I bricked my device and can't restore it.
    Thank you .
      I'm don't know where the wifi is at??
        Damn picture quality sucks...... S805 mxq v03
          Originally posted by Dmc99 View Post
          To be honest i'm not really sure what version i have ... possible 4th
          Doesn't say anything on the reverse side.
          Also you'll notice that there is only one chip right by the group of 3 usbs.
          I have the same as you, sort of. I should have really looked into it more before buying what seems to be the worst box!
          Version Marking on mainboard: KCA-008 1.1
          Pictures of mainboard: attached
          Wifi Chip: Unknown
          Known Working UPDATE rom: Stock so far
          Known working IMG rom (for USB burning tool): stock so far
          Known working Openelec version:
          Where puchased: http://www.****.de/itm/351416811830?...%3AMEBIDX%3AIT
          Any other info:
            Pictures of mainboard: See attached.
            Wifi Chip: Realtec but cant read the model number
            Known Working UPDATE rom: https://cloud.mail.ru/public/9RUK/k5VWgv44G (based on MXQ_112k4) and is called MXQ_112k4_lite_Multi.zip as it does not replace Uboot or Logo. It says on the 4pda.ru forum that may work on other devices (universal). USE AT OWN RISK.
            Known working IMG rom (for USB burning tool): https://cloud.mail.ru/public/7oSn/WunL7sMWW
            Known working Openelec version: Yes see http://freaktab.com/forum/tv-player-...268#post541268 Bootloader.img needs changing to avoid brick. Do at your own risk
            Where puchased: Amazon UK.
            Any other info:
            May be a clone, a later version of the HD18Q, or something else. I have tried about 10 different roms on this new box, including the *standard* openelec builds for HD18Q and MXQ (from Sdcard and Nand)....all result in a bricked box with no access to recovery via toothpick, no recovery via bootcard maker...Only way to recover was with USB A to A cable and USB burning tool with correct img file https://cloud.mail.ru/public/7oSn/WunL7sMWW which i found at http://4pda.ru/forum/index.php?showtopic=621980 . This firmware is marked as MXQ-S805-V1.2 (HD180_V1.2) and "for those with a brick and error when you try to restore [0x10105002] Romcode / Initialize DDR / Read initialize status / USB Control setup error" when using USB Burning tool....which is the error I was having when restoring any other img. Wifi works on this rom and so does access to recovery...Remote does not work. I do have a nandroid back up of the original (pictured below with a date of 11112015!!) which I will restore.
            EDIT: Found an OTA update at http://4pda.ru/forum/index.php?s=&sh...ost&p=44636523 that works for this device. It says it doesnt change Uboot or Logo. See link above. Be aware first boot takes about 5-10 Mins.
            EDIT2: Openelec now working after changing bootloader.img in openelec update zip (see above)
            Thank you this fixed my .MXQ-S805-V1.2.do you know were to get newest firmware for this box?
              Hi, I'd like to know wich ROM or OpenElec I can install on my MXQ.
              This is the model I have.
                I have the same box I would like to know.
                  kiodo1981 @smilez
                  How to use this thread
                  1) Look at your board markings on the main board in your MXQ
                  2) See if someone has already posted in this thread what appears to be the same board as yours.
                  3) Find the answers to your questions...
                  Easy...
                  To all that have contributed to the thread already by filling out the "template" in post 1 to help others. Thank you for helping me to help you.
                    Openelec now working on S805_MXQ_v03 board. See http://freaktab.com/forum/tv-player-...268#post541268
                    I really thank you for starting this thread!! I think I understand replacing the bootloader file but for remote config. I don't know where to begin with that and resign zip was just a whole another level to this game. I'm not tech savvy at all. I've all ready bricked 1 v03 that's why I'm just so cautious.
                      Any other info:
                      I've installed bootloader.img to test OpenElec. Now my MXQ boot is too slow.
                      Is there another bootloader.img compatible?
                        Remove
                          Could somebody tell me if this is the version v03 board..
                          Sent from my SM-G900V using Tapatalk
                            Yes. I see S805_MXQ_V03 in the pictures. It's identical mine.
                            Can you backup and update tour bootloader.IMG, please?
                            Thanks.
                              can anyone confirm that the twrp 2.8.7.0 mxq -all black works with the version s805_mxq_v03 board? I assume this is how i would backup to retrieve the bootloader.img???
                                I use TWRP 2.8.7.0 MXQ from ...
                                Hi, i did a port from abdul's twrp (http://www.freaktab.com/showthread.php?15651-TWRP-for-Amlogic-devices), so all the credit must go to him. Note: Only mouse
