Tried this firmware too but no joy! Megatrons V2 has been the most stable but then crashes when you open apps or go on tinternet. Wifi was strong and original remote worked though
MXQ "All Black" S805 Versions / HD18q / and Clones Directory
Originally posted by kostaman View PostHi There
I have the same board in the all black mxq. I have successfully run Kasz's Openelec with this board.
Very important i know which remote control you have (see pics). If you have the remote on the left use the HD 18Q Builds.
If you have the remote on the right of the picture use the MXQ Arm Builds. I have the same board as you but i have the remote on the right with the raised buttons. I run the MXQ Build 6.0.0.1 nand and it works great except wifi is very SLOW which has always been the case whatever system i've run.(rubbish chip) Power ethernet adapters are cheap.The blue button always stays on. Reboot and Clean Shut down working.
Originally posted by massy086 View Posti have the remote on the right and the same board (am mxq a 20150825) .i can run OpenELEC-Amlogic.HD18Q.arm-6.0.1.1 but have no working remote.if i run the arm build the remote works.i find the hd18q build better .is there a way to extract the remote config from the arm build and i can the ssh it to the hd18q buil;d cheers all
What difference in performance are you having ?
Originally posted by kostaman View PostI run the MXQ Arm Build as i have the same remote as you. I have no issues with it. I dont believe there is any difference in the performance.
I was running it from sd card early,r and I was getting random lockups.i will try run it from nand and see how it goes.how do u find the wifi
Originally posted by kostaman View PostDont use crap SD CARDS. Maximum i use is 16gb also. I've run off sd card as well but not a crap sd card. They are too slow.
Ye I normally run off the nand. But I was just testing builds on sd before going the whole hog nand build cheers is the wifi stable now
No problem using wifi though.
Version Marking on mainboard: MXQ_S805 V3_1 20151230
Pictures of mainboard: Yes
Wifi Chip :RTL8189ETV
Known Working UPDATE rom:
Known working IMG rom (for USB burning tool):
Known working Openelec version:
Where puchased: Aliexpress Seller Hi-Speed Tech. Co.
Any other info:
Cant get any SD card to boot, not even twrp.
Stays on MXQ logo with toothpick.
CPUz shows M201d
Build # MXQ.V2.0.201601160929
I would like to get TWRP to load so I can back up and clone the other 19 boxes.
Even better if I can get openelec to load.
You may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
Version Marking on mainboard: TXCV-S805-MXQ
Wifi Chip :RTL8188ETV
Known Working UPDATE rom: Not Known
Known working Openelec version: OpenELEC-Amlogic.HD18Q.arm-6.0.1.1
Where puchased: ****
Any other info:
CPUz shows M201d
Build Number KOT49H.20151125 test-keys
Model Number m201c_1g
EDIT: added info for working openelecYou may only view thumbnails in this gallery. This gallery has 3 photos.3 PhotosLast edited by fanni2; 14 February 2016, 19:05.
Known working Openelec version: Would love to find out
Any other info:
CPUz shows M201d
Would love to get openelec running on this and would be nice to know what version board i have if someone can tell me
Any other info:
CPUz shows M201d
Originally posted by jed View Post
fanni2 I had an all black that I didn't open as I was pretty sure I needed to return it. BUT the Build Number and date you quote and Model Number were the same ! Now one question, did you get it from an **** advertiser that made a comparison about his MXQs being Genuine and then sent one that was a Clone (according to his photos of network port) ? Anyway, my point is that if we had the same board then I was unable to get OpenElec working despite the developer 'K' suggesting it might need bumped voltages and made me a test build, but still no good. Perhaps its a slightly different version of chip too - I am not sure what the "c" on "m201c_1g" signifies. Anyway, good luck ! If its from the same supplier as mine you might wish to consider returning it as I doubt it will work on OpenElec any time soon (just froze up for me). The discussion I had about it is here. http://freaktab.com/forum/tv-player-...144#post555144
Yeah that's the same seller
Originally posted by fanni2 View PostYeah that's the same seller
There are currently 1689 users online. 1 members and 1688 guests.
