MXQ "All Black" S805 Versions / HD18q / and Clones Directory
    hmm... on 4pda...
    there might be a fix for RTL8188 / RTL8189
    Cheers
      Version Marking on mainboard: S805Q_V2.0 (datecode 2016.xx.11, where xx is either 03 or 08)
      Pictures of mainboard: https://drive.google.com/drive/folde...kU?usp=sharing
      Wifi Chip: RTL8188ETV
      Known Working UPDATE rom: Tronfy MXQ "stock" ROM (mxq-ota-0725swe)(https://mega.nz/#!wdVDUYAC!TNnxJpRgc...AdDO9mJq6JbU); JustOp Droibox(m201-ota-20160130)(https://drive.google.com/file/d/0B8l...E4RVdjWG8/view)
      Known working IMG rom (for USB burning tool): unknown thus far...still testing
      Known working Openelec version: unknown(can't get it to work for the life of me yet)
      Where puchased: Main source unknown; thru friend of a friend
      Any other info: txt file on my Drive share with markings info
        OTT TV BOX S805 V2
        Didn't saw if someone has already posted this ROM .img https://mega.nz/#!axEy0ZTL!R3BDNB3L7...G_ni807zWxdBy8
        Sticker on the bottom of device says model: TVQ55
        It is working fine on device with same info on mainboard as post above and mainboard is looking the same:
        Mainboard: S805Q_V2.0
        Date: 2016.08.11
        Here are some additional pictures
          please note:
          V3_1 : https://forum.libreelec.tv/thread-200-post-1994.html
          S805_v1_D08 and S805Q_V2.0
          Are stated as having fake ram (only having 350mb usable ram)
            I have Amiko Appo Ver.1.
            Motherboard name: YW S805 Ver.1.0. 10.15.2015
            Over USB_Burning_Tool I put Image of MXQ TV box (aml_upgrade_package_MXQ805), the device works, but I have two problems:
            The remote control does not work
            WiFi is not working
            Do you have any recommendations for further work ??
            Sent from my m8 using Tapatalk
              WiFi model: RTL8189ETV
              WiFi is not working
                WiFi is not working
                  Originally posted by mitchell4you View Post
                  please note:
                  Dang nabbit!!! Thanks Mitchell
                    Originally posted by GoranNSW View Post
                    OTT TV BOX S805 V2
                    Date: 2016.08.11
                    Hey Goran! Think I tried that one before but will again. Moreso, Mitchell's response may be the issue overall
                      Hola gracias por la ayuda que se da en este foro, necesito un firmware para una mxq s805 que no le funciona el wifi en la foto esta la versión del mxq, el firmware que tiene funciona el control y con el cable de red pero me mude y la persona que tiene el Internet solo lo distribuye wifi por eso quiero arreglar el wifi de la mxq gracias.
                      Hi thanks for the help that is given in this forum, I need a firmware for a mxq s805 that does not work the wifi in the photo is the version of the mxq, the firmware that has the control and the network cable but I move And the person who has the internet only distributes wifi so I want to fix the wifi of the mxq thanks.
                      You may only view thumbnails in this gallery. This gallery has 4 photos.
                        Hi, I found the forum looking for ROM for my BOX, I found several files of several models,
                        some start but most does not start, the biggest problem is WIFI,
                        which apparently is not used much, is the S9083C chip, I already installed all ROM that I found but none recognized the WIFI,
                        I have nowhere else to look, I have reached the end of the google search, this is my last chance to find a compatible ROM,
                        or some method for WIFI to work.
                        Date: 2016.08.11
                        Wifi Chip: S9083C
                        Click image for larger version  Name:	WhatsApp Image 2017-05-03 at 10.41.45 AM.jpeg Views:	1 Size:	97.6 KB ID:	644729
                        Click image for larger version  Name:	WhatsApp Image 2017-05-03 at 10.43.23 AM.jpeg Views:	1 Size:	107.4 KB ID:	644730
                        Click image for larger version  Name:	WhatsApp Image 2017-05-03 at 10.44.15 AM.jpeg Views:	1 Size:	94.0 KB ID:	644731
                          SmartChip Integration by Suzhou
                          Not sure how far you got but I got practically nowhere other than finding a contact email for them. There's a "test file" for downloading on the site, but you have to be a registered accountholder in order to get it. None of the 4 partners listed appear to have download areas
                          Email is [email protected]
                            I'm trying to find a newer firmware for my device because it has the bug where it wont power on with the remote, power needs to be reset for it to come back on.Anyways I opened it up and the as you can see in the pictures the board reads 'hd18q' but when I went to flash the matching firmware TWRP throws an error saying the box is a K200.When I search for k200 firmware I dont see any boxes that look like my MXQ box.
                            Does anyone know where I can find the proper firmware?
ID:	651902Click image for larger version
ID:	651901Click image for larger version
ID:	651903Click image for larger version
                              I found that hd18q-ota-20150509 will work if I edit the install script but I dont have any wifi then, if someone can do me a solid and add the wifi files from my stock rom i'd love that! just tell me which files you need
                                This box have been bricked, after installing openelec zip package from stock recovery of the device.
                                Now it only stays with red light only, not showing anything on TV.
                                I have been able to boot into "TWRP Recovery for MXQ Devices" with different u-boot.bin files with BootCard Maker, but i believe that partitions have been corruped or something similar as all of partitions shows 0MB Size.
                                Also i cannot format or wipe data on partitions as TWRP produces errors such as "cannot mount /data", "cannot find /bootloader partitions.
                                The device is recognized into PC in the moment i put USB Cable into OTG port, without pressing recovery button into AV hole.
                                So i was able to try dozens of different firmwares, but all of them fail at 4% with "UBOOT Disk Intialize Command" ERROR.
                                Does anyone have any idea which firmware or u-boot files may works for this kind of device.
                                Platform : Amlogic S805
                                Board Model : HD18Q_V2.0 with date : 2015/08/08
                                Nandchip : Sandisk P545105231 from SDTNRGAMA-008G Series ( Taiwan)
                                Wifi Model : Realtek RTL8188EUS
                                DDR : 2 x DDR Marked as PE039-125 TP ( this might be Spektek DDR?)
