So thanks to Trebor for testing my EZ root ZIP I made for the Minix U1, this also work on all the Tronsmart S95 devices.
No ADB required which is difficult for many to setup and get the drivers installed!
Trust I will do more work with the S95 boxes like ROMS!
________________________
This is a full proper root including fixing processes!
When you run the SU app for the first time you it will not have to update the SU binary which is unlike other root tools out there for the S905.
On with the show.....
Download the link below.
Unzip the file and put the 3 files on a SDcard.
ezroot.zip
recovery.img
factory_update_param.aml
Insert the SDcard into your Tronsmart S95
Unplug the power, wait 3 seconds and plug it back in.
Now this is the important part. We need to boot the recovery you put on SDcard not the internal recovery or the ezroot.zip will fail signature.
Go to "My Apps" and run "Update & Backup".
Click on "Local Update" and click on "Select". It should find ezroot.zip on your SDcard.
Select that and proceed.
The S95 will reboot and install the update and your done!
Enjoy the perfect root
Here is the download link:
https://drive.google.com/file/d/0B9B...ew?usp=sharing
Enjoy and now it is time for me to work on a Finless ROM for this box
