Tronsmart MK908 Android 4.2.2 "Official" - Finless ROM 1.5
Originally posted by Sarco View PostWhen plug in the device make sure you press reset at same time.
I am having issues similar to person above.
I am on Windows 8 with USB3 adapters on my laptop.
I had no luck with default Flash Tool method or the alternate RKBatchTool.
When I tried the manual method by using pin and inserting the usb power, I hear the windows "bong" sound. I see that the tronsmart itself doesnot boot and has blank screen and the blue light on the device is not lit. Seemed like I was on the right track and next step was to manually install the drivers.
But when I try to install the drivers next manually by going to the folder, the windows says its not found.
Is my USB3 creating issues for me to install this rom?
I dont have access to older laptop..
I know Finless somewhere said to change the setting.ini file setting which I did but that did not work either.
anyone knows?
Yes, I do make sure to press on the reset button, no light on... And the driver does seem to install : when I check the device after reboot, there seems to be one on it (provider : Fuzhou Rockship Electronics Co. Ltd. , file version 2.0).
I think the drivers are installed but the flash tool still don't detect the device, no idea why.
Thanks for your help.Last edited by Asvald; 02 July 2013, 01:48.
Originally posted by Asvald View PostYes, I do make sure to press on the reset button, no light on... And the driver does seem to install : when I check the device after reboot, there seems to be one on it (provider : Fuzhou Rockship Electronics Co. Ltd. , file version 2.0).
I think the drivers are installed but the flash tool still don't detect the devide, no idea why.
Thanks for your help.T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
Couple more attempt with a friend, not getting better. After a while though, we noticed Windows was actually installing the drivers all by itself (apparently the same we were trying to install manually since an attempt to update it showed current driver was up to date)... We aborted one such automatic installation to be sure we use the drivers provided by Finless Bob, but it makes no difference.
One other thing is that it seems the device is not really identified as an usb storage device. Probably why the flash tool won't find it. Windows assigns to it an icon that looks like an MP3 player and when looking at the system, it does not appear like a storage unit, and gets no drive letter... No idea why, or if it's really the problem (or if it is normal), even less how to fix it.
Just to know if I'm the only one with this exact problem... anyone else ever installed this firmware update with a pc running Windows 7 ?
Best regards and thanks again for all the help...
Originally posted by Asvald View PostCouple more attempt with a friend, not getting better. After a while though, we noticed Windows was actually installing the drivers all by itself (apparently the same we were trying to install manually since an attempt to update it showed current driver was up to date)... We aborted one such automatic installation to be sure we use the drivers provided by Finless Bob, but it makes no difference.
If the mass storage driver is installed automatically it makes absolutely no difference to the OS when the device is in flash mode. To the OS it is two completely different devices and two completely different device types. If it shows up as a USB mass storage device, you have done it wrong.
Originally posted by Asvald View PostHello,
first of all, please excuse me if I'm completely clueless.. pretty much a newbie in the forum, completely newbie as far as mini-PC android sticks are concerned, and not that experimented with Android in general.
Got my MK908 last week and tried to install the 'reference': Finless ROM !
Unfortunately, I never get the flash tool to find the device.
btw, if this doesn't work, drivers are not installed properly!
Just to know, is there any risk to brick the device when trying to erase nand or other steps in the tutorial ? Or if the drivers are not correctly installed, nothing will happen at all ?
Thanks Sevo, I will try your solution. Not sure what you mean by 'install android terminal'. Are you referring to this:
Will keep you posted when I have a chance to try it...
Best regards,
Asvald
nfs modules for your custom rom
Hi Bob,
Thank you for your job
I think most of us need nfs modules for this rom, because this hw enough for hd movies 20gb+/film if we can use mx player to play movies from NAS. But mx player does not play from network so we need to mount our share, so to be able to mount we need nfs modules for this rom. I took a search for 1 week but i did not find nfs modules for this rom. Is it possible to compile nfs modules for this rom and post them here, or it is not possible?
Thank you.
I am calling this a Finless 1.5 ROM to make sure there is no confusion with the
2) Stock ROM was only 2 Gig of APP space.
BUT you also have parameter file options!
There are also 1gb, 2gb, 4gb and 6gb options.
Read below for how to change that in the flash tool.
Realize if you use this 6gb option, internal SDcard will only have about 600 megs of free space!
3) Debloated of junk APPs and Google Apps you can get from Google Play.
I also updated Google Play to the latest version along with standard APPs.
4) As always, full init.d support! If you do not know what that is... ignore it. For geeks that want to use it. It is there!
5) I re-enabled location services. This is now in the settings menu.
Tested and working with all APPs that use it.
Remember to turn off GPS as we have no GPS.
6) I also re-enabled accessibility options in settings.
7) Gameloft fix. This fixes Gameloft games from crashing to the desktop.
Many of them do not run and crash to the desktop. This is due to a license check based on the device.
Special thanks to Christian Troy for inventing this fix. I modded it for this ROM.
8) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
I am spoofing a Samsung device that will show almost any APP as compatible.
Yuor device will show up in google play as Samsung device nopt a MK908 or RKSDK! Understand this please.
I also left the original build.prop in the ROM called build.orig.
If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
Then rename build.orig to build.prop.
Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
Reboot! You should be back to showing up as a MK908.
9) RK Mirroring is enabled as always.
Also new to Android 4.2.2 is Wifi display.
If you have another 4.2.2 phone or tablet you can share your devices screen on your TV.
10) Remote Control using RK Remote APP is now fully supported!
In the ROM kit is a RKRemoteControl.apk.
NOTE: This is a NEW version and will not cause your TV stick to crash.
So if you have already installed RKRemote before you need to un-install it and re-install this version!!!!
You install this on your phone or tablet and now it can remotely control your TV player!
Just put the APK on sdcard or something and install it on your Android phone, tablet, etc.
ENJOY this one! I had a HARD TIME getting it to work!
11) I added a reboot APP that will allow optional reboot options like reboot to bootloader (flash mode).
12) I have adjusted the mouse pointer size by request!
Stock rom was 55x55. The normal mouse pointer is 22x28 which is too small for many.
I made a 35x35 mouse pointer.
If you want to change that more discuss online and I will tell you how to do it.
13) 1080P Kernel if you want it! Tronsmart also released a 1080 kernel.
I have unpacked it from boot and made it a choice in this ROM package.
See instructions IN THE README for how to choose the correct boot.img and kernel.img
720P boot and kernel is the default setup in my flash tool.
For more information ALWAYS read the README in the ROM kit!
_______________________
Here are the links for Android 4.2.2 Finless 1.5 ROM
ROM -> Tronsmart MK908 Android 4.2.2 "Official" - Finless 1.5 ROM (245 megs)
Enjoy,
Bob[/QUOTE]
I am very grateful to you Finless Bob!
But there are two problems:
1:I installed the MK908 to Finless Bob's 1.5 ROM. Google Play says no compatible device, if I want to install Real Reacing 3, or Anysoftkeyboard.
2:Build.prop is edited for Samsung devices.
Init.d is not supported? Does not start automatically, for example virtual_touchsreen.ko file can not start.
Please help.
Originally posted by Asvald View PostJust to know, is there any risk to brick the device when trying to erase nand or other steps in the tutorial ? Or if the drivers are not correctly installed, nothing will happen at all ?
Problem with 1.5 ROM for Tronsmart MK908
Recently installed your 1.5 ROM for Tronsmart MK908 with 4gb & 1080p options. Everything looks good except when I use the 1080p option my Internet speed drops from around 25,000 kbps to 2,500 kbps. If I changed the setting to 720p the Internet returns to 25,000 kbps. Any idea what the problem could be?
CharlieLast edited by dogman; 04 July 2013, 15:17.
There are currently 2930 users online. 1 members and 2929 guests.
