I think we all just need to give it some time, Bob is obviously working hard on multiple things at once. I'm just glad theres a community based on these devices.
Tronsmart MK908 Android 4.2.2 "Official" - Finless ROM 1.5
I've been playing around with Netflix some more. Bob's 4.1 Rom (default 720p) seemed more stable to me. The jitter is still there for me (although it's more intermittant in 4.2), but 4.2 has locked up on me (while playing Netflix) several times while 4.1 never locked up. I still haven't figured out how to get rid of the virtual keyboard.
FYI, still having fun!
Some questions about the ROM
Hey Bob,
Thanks so much for the work, you've really done a great service for us all.
I have some questions about the ROM after comparing it to the official release
- I can't seem to extract the official release boot.img, it has a header of ANDROID rather than KRNL RKAF or RKFW. I only have the rkutils from github on Linux and don't have a windows computer to try any of the tools that run there. Of course I expect it to be different from yours, since you've added init.d support, but I'd really like to be able to examine the original and can't get to it. I'm reading the source for rkunpack to see what it's doing for the other img types and try to reverse engineer this "ANDROID" file, but if you know what's going on, I'd love to know what tools are at your disposal.
- All the apks and ndk binaries that I've compared I can correlate to the release notes you've put out, but I started digging because of the Netflix fix. I'm a bit confused... are the only changes to fix the Netflix buffering issues the changes to build.props in the "My tweaks" section? I have to ask because they're all commented out and I can't find anything else that lends itself to that fix.
- The official update didn't come with a kernel image. I'm curious where you got the 720 kernel you've included. Did you download it from the device or extract it out of the original release? I'm mainly curious because if I'm already running the 720 kernel you've got, I won't have to worry about ABI compatibility.
I can't say enough how great it is to have your work to look at, it probably would have taken be days to figure out the formats and packaging without your ROM to start with. My goal was to be able to get the kinks out of the official release without doing a full wipe. I think you've described enough in your "READ ME FIRST" file that I'm comfortable with a partial flash if I know that I'm running a compatible kernel.
Thanks again. You rock!
Brunson, the official release the kernel is in boot.img which is why you see the Android header.
Boot can be 2 ways. RK packed or standard Android style. I got the kernel from inside boot.img. You extract that style boot.img using a perl script. See the ROM hacks and development area and I explain how to do that.
I commented out my usual build.prop changes as I could not see them make any difference and feared they would cause bugs until I could test more.
As for where the Netflix fix was, I do not know. I have not had time to compare the MK908 beta vs official which between those 2 releases in one day they fixed Netflix. So it should be some what easy to figure out once I get the time.
Originally posted by alnames View PostI've been playing around with Netflix some more. Bob's 4.1 Rom (default 720p) seemed more stable to me. The jitter is still there for me (although it's more intermittant in 4.2), but 4.2 has locked up on me (while playing Netflix) several times while 4.1 never locked up. I still haven't figured out how to get rid of the virtual keyboard.
For those who still finding the way get rid of the virtual keyboard, I want to share my simple solution. Just install Q2 Keyboard from Google play market and use it. There is option to hide virtual keyboard when physical keyboard is connected. I'm using Logitech K-400 and it works fine.
Bob, thank you so much for your great Rom~!!
Jin
Jin
in my opinion the best way to hide the virtual keyboard is to install the app "Keyboard Helper".
You can also switch the keyboard layout from QUERTY to QUERTZ (necessary for german users e.g.).
Steffen
My PSU and an option to view apps as a list
I measured my PSU and the highest AMP we got was 1.17. I just ordered a 5V 3A NordicPower PSU with DC -> Mini-USB connector mod (replacement) made by the vendor. Should arrive this week.
Is there a way to make the apps show as a list instead a gazillion number of icons? My Samsung SGS III (3) has the option but it's behind a settings button. Any advice would be nice. Never used an Android tablet, let alone 4.2.2 Android inside a small Android TV. =)
BR,
-J-
Originally posted by peteus View PostAfter running 1080p kernel/rom for a few days, my observation is that unit overheats a lot and may crash during video playback.
I did add a Pentium heat sink and fan and I'm sure this would do the trick however I stopped at the thought of having to patch up a poor design.
Im not trying to dig here but making people aware before they purchase it as I did to be a faster unit than the mk808.
sgei & elecs21d:
You don't need to install anything just disable the Android Keyboard AOSP, then it may call the only input device left like speech so disable that.
Thats the first thing I do on all my android devices as my development requires full screen and a usb keyboard / mouse.
hope that helps.
Originally posted by starryeyedsky View PostI just got my MK908 in today and installed Finess Rom 1.5. My current Bluetooth keyboard and mouse don't work with it. Is this an issue with the ROM or Android OS in general?
it is not an Android OS issue in general.
The problem is in the stock firmware 4.1.2 and 4.2.2. The Finless ROM 1.5 is based on it.
The manufacturer knows about the bug and will fix it like in the T428 ROM.
These are my information from geekbuying.
We have to wait...
There are currently 3416 users online. 0 members and 3416 guests.
