help unbrick this clone
    purchased on **** thought it was original ..flashed m8 firmware bricked it .now once connected to power solid blue light with no signal to tv ..holding reset before powering up does nothing.it connects to pc usb burning tool ..detected by comp in port nearest to hdmi ..not detected in port closest to corner.tried flashing with various img files .all fail at 2 percent.tried sd card formatted with u boot and .wps file .any help would be appreciated
    motherboard M8&M9_V02
      any suggestions anyone?
        I have the exact same problem!
        Sent from my m2 note using Tapatalk
          seems no one know anything about this clone? ive tried every img file I could find.every page I see it says hold reset...reset does absolutely nothing .ive tried jumping pins 17 and 18..it fails at 2 percent every time on every rom with error
          [0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
            Does your board look like this?
            Excuse the mess and grubby fingers. I was at work
              Crap. I posted the same image twice!
Name:	m8 motherboard2.jpg
ID:	554927 Not even close.how do you upload such good photos.mine look like cap when I try to upload
                WiFi chip is rtl8723 on my board by the way
                  I use tapatalk. It sucks for some things, but uploads photos well
                    Sent from my SGH-I337M using Tapatalk
                    don't see much in forum with this board ..any links to usb load roms would be appreciated .I will try all I can find .so far i've tried 6 or 7 all fail at 2 percent
                      well I got it fired back up with aml_upgrade_package.img...now its a question of finding the right firmware
                        is there a flashable zip for rtl8723bs wifi chip... I loaded mxiii sd zip .....installed cyx m8s remote zip.I have box operational but no wifi .installed s89 root flash .twrp img installed ....installed 112k4 boot.img....seems to be working great .just gotta get wifi working...
                          you can provide this image "112k4 boot image"
                            Just gotta download 112k4 update zip install boot I'm from it with twrp
                              I have stock firmware image from identical box in twrp format.anyone know how to convert this to a usb loader Bootable Img file?
