help unbrick this clone
Good day everyone. I also having a M8&m9_v02 tvbox with 8723b wifi chip. I would like to re-flash the firmware but most of the link posted by jaynjolie is either missing or dead. Can anyone please send me the link for: 1.TWRP Bootloader, 2.AML Upgrade Package.img for USB Burning tools. Thank you~Last edited by zeroknight83; 07-21-2016, 05:58.
Originally posted by zeroknight83 View PostSorry, what I mean is I need the TWRP Bootloader for the M8 TVBox. Not the Backup recovery image.
Originally posted by mistergary View Post
Yuo can post her your backup image from yuor box?
I bricked my box before I can backup the original stock Image. So I dont have any. Now trying to recover back by using jaynjolie twrp backup image files. But when I try to flash the system files I end up getting this error: extractTarFork() process ended with ERROR=255" After I check, I notice that my system partition MAX Size is 990MB while the backup system files provided by jaynjolie is nearly 1080MB. Do you have any solution to solve this problem?
Originally posted by jaynjolie View PostUntick system on install of twrp backup then on 2nd attempt without restarting install system only utickl all others it will install.then just restart box should come on
You mean Format data then wipe everything right? I did do that everytime I try to restore your backup but still end up with same error. Then I try to use 7zip to open your "system.ext4.win" files & delete some unuse apps inside the "preinstall" folder then I save it & put into SD & flash again. This time the restoration did completed successfully but when I try to restart the box it still not able to boot up. I dunno whats wrong. Is it possible for you to create a new slimmer TWRP backup for me? Very thankful for your kindly help.
Originally posted by zeroknight83 View PostYou mean Format data then wipe everything right? I did do that everytime I try to restore your backup but still end up with same error. Then I try to use 7zip to open your "system.ext4.win" files & delete some unuse apps inside the "preinstall" folder then I save it & put into SD & flash again. This time the restoration did completed successfully but when I try to restart the box it still not able to boot up. I dunno whats wrong. Is it possible for you to create a new slimmer TWRP backup for me? Very thankful for your kindly help.
There are currently 3328 users online. 5 members and 3323 guests.
