HPH RK3288 Lollipop ROM v1.6 By Mo123
    Originally posted by icemanbrfc View Post
    Im assuming we need to turn off auto update for apps?
    Sent from my SM-G920F using Tapatalk
    Only needed for Youtube, since it's a modded add-free version with extra features.
    You can turn off auto updates for a specific app by searching for it in Google Play Store and on the top right, uncheck the setting auto update.
      Thanks Mo..
      BTW are you still working on the MM firmware to get it stable? All my streaming apps work, just not that stable
        Anybody have issues on v1. 12 where the movie just stops playing. Movie will start, then just stop completely. Not sure if it's my box acting up or what. But going to flash v.1.10
          Let me know if an older firmware don't have this problem.
          What video player are you using?
            both vlc and mx. wassers rom works great, but far too buggy. let you know
              mo123 Is it possible to install 1.12 on UT3S?
                Hi ,
                i think well , i always used Mo123 Roms on my UT3 .
                good luck / greetings / gefattern
                  Yes, it will work.
                  Do 'Eraseflash' then 'Upgrade' to flash.
                  Eraseflash is needed if flashing between different Android OS's or if the partition layout is different which in this case probably is.
                    @mo1223 It works better than last Ugoos 3.1.0. Thank you!
                      Hi ,
                      because he is a great Dev. , he even fix , Translation & Spelling errors , Ugoos did not .
                      Last i saw the "Strorage" spelling error in the Settings picture of the R99 Review from
                      Trebor , this Error exist since 4.4 , in this App .
                      I am sure the same error will come up in the new UG-R99 , Ugoos sells since short time .
                        Hi mo
                        Sorry .My English so pool
                        I used your new rom 1.12 .It's so good
                        But xposed install problem also confused me .I flash your xposed-v86-sdk22-arm- custom.zip on cwm .Either the xposed can't work on this rom .When reboot will sotp at logo,need flash xposed uninstall.zip . Just can be used normally
                        Mo can help fix problem.Please
                          Originally posted by kavana0205 View Post
                          Hi mo
                          Here is the Xposed framework to use with RK3288 Lollipop.
                          It can work on Ugoos firmware, havn't tried on mine.
                            Thx mo
                            it doesn't work. I have used this zip before.
                              I'm working on my own Marshmallow ROM.
                              Hope to get it booting and working in the next week or so
                                Thank you so much for the very good news. I thought that you would go straight to Nougat. So far Rockchip still hasn't released its 7.0 SDK yet?
