Sent from my SM-G920F using Tapatalk
HPH RK3288 Lollipop ROM v1.6 By Mo123
MO just a quick one. On this firmware, ie the one to allow bypassing of root. When i plug an external hard drive in, it's very buggy. If I select a video on my drive, it will go blue or black, then play. Once I exit that video, again it will turn blue screen and then exit.
Which player do you use?RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
You can go to Settings - Display and turn off
Adjust display frame-rate
It is used to play 24hz video smoother to not go out of sync by 1 second after 16 minutes and also to play 25/50hz video correctly
instead of at 60hz for smoother video playback.
But it will make the screen turn blue for a second each time a video is played to switch the frame-rate of the tv to match with the video.
Originally posted by mo123
Hi
Originally posted by icemanbrfc View PostThanks Mo... Just back to my 1st question, but at times I also notice flickering. Is this also part of the display frame rate?
That is auto frame-rate switching, at the end of the video it switches back to eg. 1080p@60hz, the default Android resolution.
If you just want a video to play instantly, you can disable it, but 24hz,25hz,30hz videos might then not play fully in sync with the audio.
Eg. on a RK3328 newer device, you must have auto frame-rate switching turned on in apps like Kodi to be able to play 3D or HDR video and also to play
4K videos otherwise 4K videos will play at 1080p resolution and be downscaled 4 times in quality.
Same on RK3288, 4K videos will play downscaled 4 times lower in quality at 1080p when using a 4K tv if auto frame-rate is not turned on, but playing 4K video on a 1080p tv
automatically plays at 1080p as it can't go any higher.
If there are also problems during video playback, you can send a link to a small sample video to test.
Using 'Video', MXPlayer or Kodi?
The firmware still use tablet MM code from 1 1/2 years ago and is still full of bugs.
It should work a lot better when I'm able to make Nougat firmware instead in a few months.
It only happens before video playback and when video playback ends and the screen turns black/blue?
Originally posted by icemanbrfc View PostA quick question... Is it possible to use a Harmony 1100 remote with a HPH NT-V6? Just to use the volume, power on and off and scroll around the menus?
There is also a Kodi keylayout file in the 1st post.
Not sure if the other changes are needed, if so I can try to add it later.
Originally posted by icemanbrfc View PostMO your V1.12 rom, is there a way to flash that without root? While the alternative Wassers rom is working for my streaming apps, it's just far too buggy at the moment.
But even if unrooted, you will probably still have problems with some streaming apps that have Google Certified checks.
The MM Test firmware is Google Certified that's why a lot more streaming apps work.
Nougat is a lot more updated and will work better but is still a few weeks away.Last edited by mo123; 21 January 2018, 18:18.
The v1.12 ROM can is rooted but can be unrooted/rooted again from Accessibility Options.
Hi Mo123 ,
i read your last comment : Nougat is a little bit .... still Weeks away . Will this mean you are bussy
with a Nougat Version for RK3288 ???
greetings / gefattern
There are currently 2092 users online. 1 members and 2091 guests.
