Tried playing 1080p on this device from a NAVIX stream from within an XBMC libstagefright version - it crashed the stick, then when I went to touch it - it almost burnt my fingers off. I notified BOB but no response so I thought I would just let you all know - mine is the 1gb version. We are talking fire hazard hot - so I am not sure if it is a problem with this ROM or the stick in general.
CX-919 4.2.2 - Finless ROM 1.4
HOT HOT HOT - FYI
Originally posted by bloatman View PostI have the 2gb version and I'm still on the stock 4.1.1 rom. I installed an overnight build of xbmc and navi-x and had no heat issues at all.
Was it: xbmc-frodo-12.1-xaf-neon-set_top-20130503-47b0a23c60.apk ?
from here, here
Originally posted by psolord View PostThanks again for your great support.
I just finished installing the 4.1.1 though along with 20GBs worth of apps and I am pretty happy with it. Also I use directory bind which is not compatible with newer versions of Android, so I will probably stick with it.....What version of directory bind are you using im try to figure that out would be great if i could get it working think i must be using a buggy version of it im trying to use directory bind 0.2.0.o
http://mirrors.xbmc.org/nightlies/android/Originally posted by britoso View PostPlease post links to those.
from here, here
SDCard getting unmounted
Every so often (~12 hours) I get a "Blank Internal Flash - Internal flash blank or has unsupported filesystem." notification. On clicking it it asks me if I want to format the SDCard.
- Under Setting>USB-> Connect to PC gets set to true (checked, tried unchecking it, did not help)
- Under Setting->Storage->SDcard, I am unable to mount/unmount it. (did not work)
The only thing that works to re-mount the sdcard is a reboot. Any ideas why this is happening?
Edit: This may be due to me moving the wired mouse, my cx919 is prone to power resets with the slightest motion, maybe the sdcard loses contact too.Last edited by britoso; 26 June 2013, 09:51.
easy erase and flash!
hi everyone, i followed the instructions how to flash and i was supprised of how easy it was.. took 2 gb parameter and flashed it .. the rom works great, but i have problems with antutu.. i had the same problem with stock rom, it reboots in the middle of tesing, but on stock rom i heard that it was a problem with the power that i should check the ac adapter, so i changed the china to eu plug to a different and that solved the problem with antutu on stock.. but now with the finless rom i dont know what the problem is.. :S same shit.. but any ways i flashed also the generic rk30x recovery image from www.androidtab.info it only workt with replacing the recovery.img in finless rom and with ROM_flash_tool_137 flashing it..
so now i have cwm also..
and for swedish users like me i use external keyboard helper pro for using åäö digits
ipega bluetooth gamepad
hi again.. i have tried some usb joysticks cant get anyone of them working.. i have used joystick center and tincore keymapper.. anyone got some experience with gamepads feel free too post .. the games seems to work fine doh.. all of the time a analog isnt working or cam spinning around.. anyways i will get a ipega bluetooth gamepad next week who are supported with android.. i would really get some games with a controller working.. thoose who i have tried with is a Xbox 1 usb controller and a dual psx controller.. cheers
Originally posted by phozac View Posthi everyone, i followed the instructions how to flash and i was supprised of how easy it was.. took 2 gb parameter and flashed it .. the rom works great, but i have problems with antutu.. i had the same problem with stock rom, it reboots in the middle of tesing, but on stock rom i heard that it was a problem with the power that i should check the ac adapter, so i changed the china to eu plug to a different and that solved the problem with antutu on stock.. but now with the finless rom i dont know what the problem is.. :S same shit.. but any ways i flashed also the generic rk30x recovery image from www.androidtab.info it only workt with replacing the recovery.img in finless rom and with ROM_flash_tool_137 flashing it..
the rom works well in all models?
Any chance you can provide a working link to this RK30x thing along with a little more detail - I would love to have CWM on this device
There are currently 2545 users online. 0 members and 2545 guests.
