CX-919 4.2.2 - Finless ROM 1.4
Thats awsome
Originally posted by phozac View PostUse the link i posted.. Download the generic image from link.. Unpack finless rom.. I am on my cell now but i think in the folder rom u have all the i the images.. Copy the recovery.img and save as stockrecovery.img then place the generic image from the link in the same folder.. Open up flash tool and untick everything besides recovery.img you know how to flash or else read the readme in finless rom.. Can update when i have time and i am on my computer home..
Originally posted by phozac View Postatleast mine. i dont know if i have a bad unit or not but.. everytime i run with ac adapter who came with the box on finless rom antutu reboots in the middle of benchmarking.. anyway i was thinkin that i was the ac adapter.. u maybe can use one if it have like a ac adapter with 3.0 ampere or something like that output.. the 2.0 ampere seems to be weak when it comes to 4.2.2 roms..
but it works when u have 2 connected at the same time.. :S i dunno
same problem
Originally posted by britoso View PostEvery so often (~12 hours) I get a "Blank Internal Flash - Internal flash blank or has unsupported filesystem." notification. On clicking it it asks me if I want to format the SDCard.
- Under Setting>USB-> Connect to PC gets set to true (checked, tried unchecking it, did not help)
- Under Setting->Storage->SDcard, I am unable to mount/unmount it. (did not work)
The only thing that works to re-mount the sdcard is a reboot. Any ideas why this is happening?
Edit: This may be due to me moving the wired mouse, my cx919 is prone to power resets with the slightest motion, maybe the sdcard loses contact too.
CWM on Finless4.1.1?
Originally posted by phozac View Post1: download finless rom http://www.freak-tab.de/finless/cx919_422_finless14.zip
2: unpack to desktop
3: download recovery http://files.androtab.info/rockchip/...ENERIC_CWM.zip
4: unpack recovery into Desktop\CX919_4.2.2_Finless_14\FinlessROM\ overwrite or rename the stock recovery.img
5: hold down fn button on cx and at the same time plugin in the usb cable to computer
6: install drivers Desktop\CX919_4.2.2_Finless_14\drivers
7: reboot
8: hold down fn button on cx and at the same time plugin in the usb cable to computer
9: open up C:\Users\phozac\Desktop\CX919_4.2.2_Finless_14\ and open ROM_Flash_Tool_137.exe
10: untick everything besides RK3188Loader(L)_V1.20.bin and recovery.img
11: hit flash rom
The cwm recovery supports keyboard make sure u have one plugged in or else u cant go up and down in the menus..
I am also having the video frame dropping issue where if you move the mouse the problem disappears.
Additionally in Netflix, when it changes the quality levels during the buffering phase, sometimes the audio disappears on the movie and only comes back if you reopen it
Also, when running Antutu, it crashes the CX919 and makes it reboot.
i dont know
Originally posted by peety View PostIs there any reason that CWM can not be flashed on the 4.1.1 Finless ROM.? Would hate to brake it.
Logitech C170 stopped working
Hi, I installed the ROM and I am happy with RKRemoteControl and anything else except usb camera. The Logitech C170 usb camera worked perfectly with official 4.2 ROM (tested in Camera app and Skype). After installing the CX-919 4.2.2 - Finless ROM 1.4 the camera stopped working. Any idea to getting it working? Thank you.
Anybody else get a heat problem with this ROM?
It's a little weird but my CX919 get's really hot and reboots using this ROM - wondering if this ROM is overclocked? or if anyone else has the problem.
I also have the Nand Flash partition just disappear on me as well - it returns after a reboot - strange behavior. Have not tested the stock rom enough to know if this a problem with this ROM or the stick itself.
Now the thing won't boot without over heating and then rebooting - oh well. Will post again when I have an answer.Last edited by gollygosh; 04 July 2013, 10:46.
There are currently 2376 users online. 2 members and 2374 guests.
