Hi everyone new to all this I have an android box scishion V88 4k iy was working fine now all I get is a green screen. I have reset the box and when I go to reboot it its freezes on the android screen, when I unplug it and power it on all I get is a green screen can any one help.
SCISHION V88 RK3229 4K Android 5.1 KODI TV BOX 1G/8G WIFI LAN Dolby DTS
Hi bomber51 ,
please send the link where you bought it to see it , it is easier to help then .
We must know what WifiChip the Box uses , otherwise a flash of the Rom could brick the Wifi .
that is normal because u tried to flash a Rockchip Box with a Amilogic Tool , did you download
the Firmware & Tools from the
Link i send you : (Installing Drivers as Admin , running Batchtool , too)
http://chinagadgetsreviews.com/downl...y8-tv-box.html
and look here for better understanding :
http://ugoos.net/blog/rockchip-firmw...flashing-guide
answer if you need more help . greetings
gefattern (i am from Germany)(my Nickname)
Hi! I have a problem with joysticks via usb port: the 4 axis buttons, start and select, and A and B work perfectly but the other buttons absolutly doesn't works. I tried to see with programs like gamepad tester the result of the value is =0. It is the same with different controllers and there is no way to remap: the tv box gives value =0 with all re mapper program.
Thank you for helping me!
Originally posted by Natureboy View PostHi! I have a problem with joysticks via usb port: the 4 axis buttons, start and select, and A and B work perfectly but the other buttons absolutly doesn't works. I tried to see with programs like gamepad tester the result of the value is =0. It is the same with different controllers and there is no way to remap: the tv box gives value =0 with all re mapper program.
https://play.google.com/store/apps/details?id=com.dancingpixelstudios.sixaxiscontroll er&hl=en_GBR-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by bomber51 View Postno idea still trying to sort mine out
Originally posted by mihai_brb View Post
I have installed this firmware the specktek 2017-06-06 version on my v88 3229 processor and i think it is verry fast it is rooted. google play works fine .netflix work fine but cannot be updated to latest version, no chipset suport. Resolution is the same 720p upscaled to 1080 but that can be canged with nomone resolution changer just write 1920x1080 and 240ppi so that it fils the screen just checkit on youtube. As for overclocking , the only change is to set it to performance , the kernel does not have any scheduler. Maximum speed is 1430 mhz.
There are currently 1755 users online. 2 members and 1753 guests.
