NEW - Android 6.0.1 Marschmallow - Wasser 64bit Firmware for Beelink R68 with Gigabit LAN, WIFI AP6335
    version 4.0.2
    • fixed issue in (un)root the device
    • added menu to specify the region code for WIFI (Settings->Wifi->Advanced Wi-Fi->Wi-Fi region code)
    • fixed crash in Settings->Display
    • fixed the state of "connect to usb" which is lost after reboot
    • added option advanced reboot, it allows to enable/disable reboot in recovery, booloader in power menu
    • added menu for Color mode which allows the user to specify the color mode (Settings->Display->Color mode)
    • improved the streaming amazon instant video
    • enabled "adjust display refresh rate" by default
    • fixed USB camera and another USB issue
    • fixed playing video issue in browser
    • fixed many security issues
    • updated superuser
    • improved the video streaming and stability for the latest RKMC and othe media player apps
    • updated es file manage
    • updated google apps
    Firmware download: 64bit-wasser-firmware-mmallow-4.0.2
    version 4.0.1
    • added SPDIF passthrough support
    • added mullti windows support
    • added menu option to hide the hdmi screen, it's required for DRM apps (menu Settings->Display->HDMI checking)
    • added support "Adjust display refresh rate"
    • made RKMC working
    • fixed issue "wifi doesn't support channels above 12"
    • added WiFi 5Ghz support
    • improved wifi performance
    • fixed issue in mount device
    • added A2 Lite airmouse support
    • ir-remote full support
    • improve HDMI settings and screen scale setting (move HDMI setting to Display Setting)
    • added lockscreen and daydream support
    • added menu option to allow (un)root the device (menu Developer options->Root access)
    Firmware download: 64bit-wasser-firmware-mmallow-4.0.1-final
    version 4.0.0 beta1
    • firmware based on marschmallow 6.0.1
    • firmware 64bit
    • support HDMI sound, SPDIF and HDMI Bitstream
    • support tvout
    • support ethernet
    • support wifi
    • support bluetooth
    • support LED
    • full support ir remote
    • init.d support
    • sdcard support
    • webcam support
    • nfs filesystem support
    • exfat filesystem support
    • xposed support
    • added hide/show navigation and statusbar
    • added poweroff button in navigation bar
    • added softreboot, reboot in recovery and bootloader
    • added "clear all recent apps" button
    • fixed ramdom ethernet MAC adress
    • multiuser support
    • add statusbar, navbar
    • added rotation support
    • fixed bootloop issue by flashing of new firmware
    • root device
    • google apps
    • added menu option for "Connect to PC"
    • support netflix, google play video
    It's the my first firmware release based on marschmallow 6.0.1, all basic stuffs should work fine. be warned, it still has some bugs,
    and many features are still missing in this release. Please report feedbacks so i can improve it in future release. Thanks
    Firmware download: 64bit-wasser-firmware-mmallow-4.0.0-beta1
    Howto get log files: get-a-logfile
    Thanks wasser.Is the GPU activated?
      Would this also work in Tronsmart R68? Has anyone tried?
      Also, wasser, changing this to support 100M lan can be done by replacing a driver via some file or is much more involved?
      Tronsmart Orion R68 Meta
      CS968 -> HTC_T018 v4 20131216 with MTK
      GM282 (aka CX 919 II aka J22) - dead
        Originally posted by wasser View Post
        version 4.0.0 beta1
        • firmware 64bit
        • support tvout
        • support ethernet
        • support wifi
        • support bluetooth
        • support LED
        • init.d support
        • sdcard support
        • webcam support
        • xposed support
        • multiuser support
        • root device
        • google apps
        Download not working
            Download url is fixed
                Afterdownloading , can't open file? 7zip or winraw don't recognise the file
                  Hi, I was able to download and install...just remove the dash at the end of the file so 7zip can recognize...running it on my Z68...faster than followmsi's rom..Antutu score at 37,500..however reboots once in a while probably heat related...
                    Thanks for that
                      Thanks. Is this Beelink i68 component wise compatible with my Tronsmart R68? Also, is there possibility that you would make 100M LAN version of this ROM?
                        wifi not working ... says its turning on and then nothing ... i rebooted and everything .... i have a beelink i68
                          unable to get Kodi working with any version ie. SPMC, RK, Kodi,..so far the only program that crashes on me...
                            I installed this Rom to my Tronsmart R68 Meta.
                            I seem to be having issues with storage. My USB and SD cards apear to be corrupt according to Android. Es file explorer seems to see the USB stick reliably but only occasioally sees the SD card.I would like to use Titanium Backup...but it does not see my SD card!
                            Any ideas? Should I reinstall the Rom?
                            Ps just checked ES and it sees neither storage device...Doh!!!
                            Weird keyboard issues. I use Firefox and in order to view the page properly when the browser is opened I have to hit the "Windows key" then back with my mouse. Now the windows key puts the box to sleep!
                              "Display" settings crash "settings" app after clicking on it... Everything else works so far... And i liked "clean" rom without 3rd apps like Kodi, Netflix, ect..
                              P.s: found that "Display" bug - if you change language to any other - it's crash..
