NEW - Android 6.0.1 Marschmallow - Wasser 64bit Firmware for Beelink R68 with Gigabit LAN, WIFI AP6335
Hey, thanks for this firmware. However, I noticed that it has the "Logitech K400 keyboard bug" that's described here:
http://freaktab.com/forum/tv-player-...-enter-key-bug
The short story is that when I press the "enter" key on the keyboard, it acts more like a mouse click and opens whatever the mouse pointer is pointing to. There is a workaround, and that is to hold "FN" while pressing "enter" and it will do what it's supposed to do. This keyboard works just fine on some of my Android boxes, but I see the same bug on the other boxes. I've heard that this can be fixed by modifying a file that defines the keyboard mapping, and I would be glad to try this myself if I knew what to edit. Ideas?
I also have a Microsoft wireless keyboard, and it works just fine with all my Android boxes, so there's something weird about the Logitech keyboard.MXQ / M8S+ / MXIII-Plus / Mini MX / Mini MXIII / T95 / Mini M8S II / R68 / V88 / GT1
I tested version 4.0.2 on My Z4 every thing else works fine but I have an I issue. I can not get notification and clock/wifi/bluetooth setting at top also standard android navigation bar at bottom is also missing (Home recent power button etc). Is it a known issues any work around or solution to this issue?
Originally posted by vinaysharma76 View PostI tested version 4.0.2 on My Z4 every thing else works fine but I have an I issue. I can not get notification and clock/wifi/bluetooth setting at top also standard android navigation bar at bottom is also missing (Home recent power button etc). Is it a known issues any work around or solution to this issue?
Thanks Wasser for this firmware.
I'm using it on Tronsmart Orion R68 Meta.
Th reason why i changed firmware was mostly for the Audio stutter problem that seems to be from Rockchip.
I noticed that your firmware does not have audio stutter issue, but instead of stutter, the sound cuts, it is less anoying.
So it seems the problem is still there, but instead of the sound stuttering it goes on and off. (like mute button)
Is this problem completely fixable or not at all?
There are currently 2090 users online. 1 members and 2089 guests.
