NEW - Android 6.0.1 Marschmallow - Wasser 64bit Firmware for Beelink R68 with Gigabit LAN, WIFI AP6335
Successfully flashed last Wasser. Impressed! Finally I can use my Tronsmart R68G as I intended. No stuttering sounds, Quick and snappy. Storage integrated, Sees large USB disks correctly. Still have not tested 4K screen, but will when I get my hands on my sons R68G. (A question mark on the performance of Ethernet port. Looked good initially but after a while poor. Need to test this more to exclude other equipment problems.)
Originally posted by Marc4711 View PostFlashed the latest on Beelink i68 and works great. Had to fix the wifi but no biggie. Thanks! The one issue I have is that the ethernet is not working. Anybody have the same issue? Any solutions?
Originally posted by symish View PostHi
first time here, does anyone have a link with instructions on how to flash this rom?
thanks in advance
Originally posted by nico1983 View PostMaybe I arrived a little late to the party, but I want to ask a question, I installed this rom (version 2), I did the wifi fix, everything is fine, but the remote control does not work anymore? I have to do something to make it work or I keep it in a drawer.??
you can use a AirMouse or BTMouse for navigation , much better then stock remote ,
Keyboard with Mouse , the best , good luck / gefattern
Hi guys,
After hours reading this forum and test many roms, finally i found a firmware that is compatible with my i68g.
The wasser rom was the best for me.
I had some troubles in the begginig with the audio, but after unninstall the ES File Explorer, everything works fine.
Now its running ok, but i had a little sound gap. Nothing irritating as before, when i had an annoying audio and video stutter. I can live with the small audio gap.
I want to thanks Wasser by his work and you guys, by the help you don't know you're giving to me by post yours doubts and exeperiences.
My Tv Box is a
I68G
2 GB RAM, 16 GB max storage,
RK3368 / Cortex-A53 chipset
Now with a Wasser firmware version 4.0.2
There are currently 2025 users online. 0 members and 2025 guests.
