NEW - Android 6.0.1 Marschmallow - Wasser 64bit Firmware for Beelink R68 with Gigabit LAN, WIFI AP6335
Originally posted by esjofrg View PostActivator, totally agree with you. Looks, and works like a complete commercial product. For Beelink R68G Wasser the best firmware. I would like a new version from him).Last edited by uli-hh; 20 April 2017, 12:55.
Originally posted by uli-hh View Post
I totally agree with both you. I hope there will be a new version with WIFI AP6330 support for the Beelink I68G.
Originally posted by 8Ross8 View Post
Work with Beelink I68G! Read this guide, works perfectly!
http://freaktab.com/forum/tv-player-...ap6330-chipset
Hi All,
Wasser thanks a lot for this!
It is working nicely in my Tronsmart R68 Meta, just got two issues:
1. The google store does not detected the pre installed apps - but not a big issue
2. After updating the simplink (LG) the tv remote control is not working with the R68 anymore - any help on this one gents?
Cheers!Last edited by paiva; 16 May 2017, 16:43.
Originally posted by wasser View Postversion 4.0.2- fixed issue in (un)root the device
- added menu to specify the region code for WIFI (Settings->Wifi->Advanced Wi-Fi->Wi-Fi region code)
- fixed crash in Settings->Display
- fixed the state of "connect to usb" which is lost after reboot
- added option advanced reboot, it allows to enable/disable reboot in recovery, booloader in power menu
- added menu for Color mode which allows the user to specify the color mode (Settings->Display->Color mode)
- improved the streaming amazon instant video
- enabled "adjust display refresh rate" by default
- fixed USB camera and another USB issue
- fixed playing video issue in browser
- fixed many security issues
- updated superuser
- improved the video streaming and stability for the latest RKMC and othe media player apps
- updated es file manage
- updated google apps
Firmware download: 64bit-wasser-firmware-mmallow-4.0.2
version 4.0.1- added SPDIF passthrough support
- added mullti windows support
- added menu option to hide the hdmi screen, it's required for DRM apps (menu Settings->Display->HDMI checking)
- added support "Adjust display refresh rate"
- made RKMC working
- fixed issue "wifi doesn't support channels above 12"
- added WiFi 5Ghz support
- improved wifi performance
- fixed issue in mount device
- added A2 Lite airmouse support
- ir-remote full support
- improve HDMI settings and screen scale setting (move HDMI setting to Display Setting)
- added lockscreen and daydream support
- added menu option to allow (un)root the device (menu Developer options->Root access)
Firmware download: 64bit-wasser-firmware-mmallow-4.0.1-final
version 4.0.0 beta1- firmware based on marschmallow 6.0.1
- firmware 64bit
- support HDMI sound, SPDIF and HDMI Bitstream
- support tvout
- support ethernet
- support wifi
- support bluetooth
- support LED
- full support ir remote
- init.d support
- sdcard support
- webcam support
- nfs filesystem support
- exfat filesystem support
- xposed support
- added hide/show navigation and statusbar
- added poweroff button in navigation bar
- added softreboot, reboot in recovery and bootloader
- added "clear all recent apps" button
- fixed ramdom ethernet MAC adress
- multiuser support
- add statusbar, navbar
- added rotation support
- fixed bootloop issue by flashing of new firmware
- root device
- google apps
- added menu option for "Connect to PC"
- support netflix, google play video
It's the my first firmware release based on marschmallow 6.0.1, all basic stuffs should work fine. be warned, it still has some bugs,
and many features are still missing in this release. Please report feedbacks so i can improve it in future release. Thanks
Firmware download: 64bit-wasser-firmware-mmallow-4.0.0-beta1
Howto get log files: get-a-logfile
I want to ask if there's a chance to put in this rom normal 100 lan and AP6255 drivers so i can try it in my SCISHION V99 Star rk3368.
This rom or this box is a ****in shit!!! Cant do shit with it.
Just wish i can make some use with it , cause for now, its useless.
Thx bro
Originally posted by miiike View Post
Hi man, how r u?
Thx bro
I haven't seen any RK3368 devices with that hardware yet, so no Marshmallow firmware will work correctly on it.
Get a RK3328, it supports lots more video formats, runs Nougat and is even cheaper.
Best will be to return the box if you still can or sell it.
Originally posted by Aaron407 View PostCan anyone confirm if there is a kodi build for this firmware that works properly with bitstreaming audio over HDMI, and whether or not 24p autoswitching with synchronized bitstreamed audio is working?
There are currently 1634 users online. 3 members and 1631 guests.
