NEW - Android 6.0.1 Marschmallow - Wasser 64bit Firmware for Beelink R68 with Gigabit LAN, WIFI AP6335
Originally posted by tsukaza View Post
ROM is super fast and my keyboard is working fine, did you turn on the hardware keyboard option ?
Since you mentioned hardware keyboard. I had to unplugged the mouse I was using and disable the android remote app installed. I was so surprise the keypad pop up. Luckily too I was able to find the option to enable the hardware keyboard. Now everything is plugged in and everything works flawlessly. Thanks.
There are currently 2469 users online. 0 members and 2469 guests.
